Replace old style
Replace old style
alessandro_m1991
Replace old style
alessandro_m1991
Hi, I am replacing some old drawing using "drawing resource transfer wizard", the problem is that I also have to replace the old styles with the new ones.
Both styles are already present in the idw file.
I am doing it manually as in the attached figure, is there a way to automate the procedure through ilogic?
Use inventor 2021.
Thank you!
alessandro_m1991
I found this function, could it be used to do what I explained?
ThisDrawing.Document.StylesManager.ReplaceStyles
Can anyone help me?
Thank you!
If you want to update your styles then use this code
Sub Main()
	Dim currentDocPath2
	currentDocPath2 = ""
	Try
		 currentDocPath2 = ThisDoc.PathAndFileName(False)
		Logger.Info("er gemt i " &  currentDocPath)
Logger.Info("Er gemt før")
		Catch
			Exit Sub
		End Try
		Logger.Info("Se om den lægge i factory mappen", "Title")
		Logger.Info("er gemt i " &  Left(currentDocPath2, 40))
	Logger.Info("Kør purge og Update Style")
	UpdateStyle3d
	PurgeStyle3d
End Sub
Sub UpdateStyle3d()'Try
Logger.Info("update")
Dim oCM As CommandManager
     oCM = ThisApplication.CommandManager
    Dim oCD As ControlDefinitions
     oCD = oCM.ControlDefinitions
    Dim oUpdateStyles As ControlDefinition
     oUpdateStyles = oCD.Item("PurgeStylesCmd")
    oUpdateStyles.Execute2 (False)
    AppActivate(ThisApplication.Caption)
	'SendKeys.Send("y")
	SendKeys.SendWait("y" & "{Enter}")
   ' SendKeys.Send("{Enter}")
    ThisApplication.UserInterfaceManager.DoEvents
	'Catch
		Logger.Info("fejl")
	'End Try
End Sub
Sub PurgeStyle3d()'Try
Logger.Info("Purge")
     oUpdateStyles = oCD.Item("UpdateStylesCmd")
	'SendKeys.Send("y")
	'Catch
		Logger.Info("fejl")
	'End Try
End Sub
