make centermark in thread holes with Ilogic
gma
gma
Is it possible to make a rule with ilogic, so you can put a center marker in all threaded holes on the idw drawing.
And there schall not bee any center mark in regular holes.
Accepted solutions (3)
dalton98
The threaded holes have a second circle on the outside of the hole. Then you should be able to check if the edge type of the circle is threaded.
Dim oDrawingDoc As DrawingDocument = ThisApplication.ActiveDocument
Dim oSheet As Sheet = oDrawingDoc.ActiveSheet
Dim oView As DrawingView = oSheet.DrawingViews.Item(1)
Dim oCurve As DrawingCurve
For Each oCurve In oView.DrawingCurves
	If oCurve.EdgeType = DrawingEdgeTypeEnum.kThreadEdge
		Dim intent1 As GeometryIntent
		intent1 = oSheet.CreateGeometryIntent(oCurve)
		oSheet.Centermarks.Add(intent1)
Next
Curtis_Waguespack
Hi @gma
If you need to run this over all views in the sheet, note that projected views with hidden lines might result in the top edge of the hole being picked up and a center mark applied, which would typically not be what we want. Something like this example will allow those linear thread curves to be skipped.
I hope this helps.
Curtis
For Each oView In oSheet.DrawingViews
		If Not oCurve.EdgeType = DrawingEdgeTypeEnum.kThreadEdge Then Continue For
		If oCurve.ProjectedCurveType = Curve2dTypeEnum.kCircleCurve2d Or _
			oCurve.ProjectedCurveType = Curve2dTypeEnum.kCircularArcCurve2d Then
	Next
Next
gma
Thanks It works, but not on a flat pattern...
it is also possible to make it work on flat pattern?
gma
Everything is working and also on flatpatterns.
Thank you
