Replace file and modify occurence name
TONELLAL
Message 1 of 8
TONELLAL
I need to rename and replace occurences in an assembly, then modify the occurence name.
I rename and replace only Farme generator components, which is tested by <condiftion>.
What I want to do :
- Num = ABC
- Original filename = toto.ipt
- New filename = ABC_toto.ipt, and Occurence name = ABC_toto
The code :
fileDir contain the file path
docFName contain the original file name (for example, toto.ipt)
Num contain the prefix to add to the name and the occurence name (for example, ABC)
If <condition>Then
                            New_name = fileDir & Num & "_" & docFName
                            Call oFileNameOcc.SaveAs(New_name, True)
                            Call oOccurrence.Replace(New_name, False)
                            oOccurrence.name = Num & "_" & oOccurrence.name
End If
The problem is, the first time I use the macro, the prefix is added twice in the occurence name (the filename is ok) : I obtain ABC_ABC_toto. This happen only the first time, and only on an orrignal Frame Generator assembly.
If I use the macro again, with for example Num = 123, the result is : 123_ABC_ABC_toto.Where is the problem ?
Replies (7)
Message 2 of 8
xiaodong_liang
Autodesk Support
Autodesk Support
using a simple assembly with a frame generator and the code below, I did not hit the problem you mentioned. The attachment is a snapshot.
Sub test()
Dim oTopAss As AssemblyDocument
Set oTopAss = ThisApplication.ActiveDocument
Dim oTopDef As AssemblyComponentDefinition
Set oTopDef = oTopAss.ComponentDefinition
oTopDef.Occurrences(2).Name = "123" + oTopDef.Occurrences(2).Name
Dim oSubAss As AssemblyDocument
Set oSubAss = oTopDef.Occurrences(2).Definition.Document
Dim oSubDef As AssemblyComponentDefinition
Set oSubDef = oSubAss.ComponentDefinition
oSubDef.Occurrences(2).Name = "123" + oSubDef.Occurrences(2).Name
End Sub
Message 3 of 8
TONELLAL
Perhaps is it because I replace the file and rename the occurrence ?
Or a 2010 bug...
oOccurrence = openDoc.AllReferencedDocuments.ComponentDefinition.Occurrences
To get the occurence document, your code use "oOccurrence.Definition.Document", mine use "oOccurrence.ReferencedDocumentDescriptor.ReferencedDocument".
What is the difference ?
Message 4 of 8
xiaodong_liang
Autodesk Support
Autodesk Support
I replaced with ReferencedDocumentDescriptor.ReferencedDocument as below. It still works. I have no Inventor 2010 installed. If you could post your code demo, I could give a try at my Inventor 2013.
Sub test()
'Set oSubAss = oTopDef.Occurrences(2).Definition.Document
Set oSubAss = oTopDef.Occurrences(2).ReferencedDocumentDescriptor.ReferencedDocument
End Sub
Message 5 of 8
TONELLAL
Here is the code : Sub Renommer_fers() ''Rename all FG components by adding a number at the beginning of the file name. Files are renamed and replaced in the assembly. Occurrences name is modified too. Dim openDoc As Document Dim docFile As Document Dim oFileNameOcc As Document Dim oOccurrence As ComponentOccurrence Dim Num_aff As String Dim Debut_nom_fichier As String Dim Nouveau_nom As String Set openDoc = ThisApplication.ActiveDocument For Each docFile In openDoc.AllReferencedDocuments 'Browse all files referenced by active assembly 'Format file name Dim FNamePos As Long FNamePos = InStrRev(docFile.FullFileName, "\", -1) Dim docFName As String Dim fileDir As String docFName = Right(docFile.FullFileName, Len(docFile.FullFileName) - FNamePos) 'Is it a FG component ? On Error Resume Next Dim Frame_OK As Boolean Frame_OK = False Frame_OK = docFile.ComponentDefinition.AttributeSets.Item(1).name = "com.autodesk.FG" On Error GoTo 0 'If it is an assembly and it is a FG component... If docFile.DocumentType = kAssemblyDocumentObject And Frame_OK Then Num_aff = InputBox("Traitement de " & docFile.FullFileName, "Renommage des profilés", "Numéro d'affaire") 'Ask for number to use as prefix for renaming files If Num_aff <> "" Then 'Num_Aff = "" 'If user click Cancel For Each oOccurrence In docFile.ComponentDefinition.Occurrences 'Browse occurrences Set oFileNameOcc = oOccurrence.ReferencedDocumentDescriptor.ReferencedDocument FNamePos = InStrRev(oFileNameOcc.FullFileName, "\", -1) fileDir = Left(oFileNameOcc.FullFileName, FNamePos) docFName = Right(oFileNameOcc.FullFileName, Len(oFileNameOcc.FullFileName) - FNamePos) Debut_nom_fichier = Left(docFName, Len(Num_aff)) If Debut_nom_fichier <> Num_aff Then 'if the filename beginning is different from the prefix, rename and replace Nouveau_nom = fileDir & Num_aff & "_" & docFName Call oFileNameOcc.SaveAs(Nouveau_nom, True) Call oOccurrence.Replace(Nouveau_nom, False) oOccurrence.name = Num_Aff & "_" & oOccurrence.name 'oOccurrence.name = Left(Num_aff & "_" & docFName, Len(Num_aff & "_" & docFName) - 4) End If Next End If End If Next End Sub
Message 6 of 8
xiaodong_liang
Autodesk Support
Autodesk Support
Sorry, the code is not well formatted. Could you re-post it? Thanks.
Message 7 of 8
TONELLAL
I think it is better :
Sub Renommer_fers()
'''Rename all components ao a Frame Generator assembly by adding a prefix at the beginning
'''Files are renamed and replaced in the assembly. The occurrence name is modified.
    For Each docFile In openDoc.AllReferencedDocuments 'Parcourir tous les fichiers référencés par l'assemblage courant
            'Format  file name
            Frame_OK = False
            On Error GoTo 0
            'If it is an assembly and a FG component...
                Num_aff = InputBox("Traitement de " & docFile.FullFileName, "Renommage des profilés", "Numéro d'affaire")  'Ask for prefix, to rename parts
                 If Num_aff <> "" Then 'Num_Aff = ""if user clicked Cancel
                        If Debut_nom_fichier <> Num_aff Then 'If the beginning of the file name is different from the prefix, rename and replace the part
                            'oOccurrence.name = Num_Aff & "_" & oOccurrence.name
                        End If
                    Next
                End If
            End If
    Next
End Sub
Message 8 of 8
xiaodong_liang
Autodesk Support
Autodesk Support
The attachment is the test video in Inventor 2013. Please check anything I missed to reproduce your problem.
