Replace and rename Component
machiel.veldkamp
machiel.veldkamp
I saw this piece of code last week somewhere online. I'm looking for it but I can't find it.
It does the following:
Setup:
ASSY.iam
- Part1.ipt
- Part2.ipt
- Assy2.ipt
_____
Run rule does:
STEP 1: Ask user to select component (e.g. part1.ipt)
STEP 2: Input new name (e.g. B500.ipt)
STEP 3: Copy selected file and rename to INPUT NAME
STEP 4: Replace component in ASSY.iam
STEP 5: Rename Part1.ipt to Part1 - B500.ipt
New Situation:
ASSY.iam
- B500.ipt
- Part2.ipt
- Assy2.ipt
____________________
Has anyone encountered this one? I'm looking for exactly this at the moment.
If not... Help making it pretty please?
Thanks for reading.
Cheers
___________________________
Owner2229
Here you go. Note: This rule won't affect any occurrences of the replaced part in subassemblies.
'Get the selection from user
Dim oSelect As Object = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAssemblyOccurrenceFilter, "Pick a part occurrence.")
'Exit if nothing is selected
If oSelect Is Nothing Then Exit Sub
'Convert to occurrence
Dim oOcc As ComponentOccurrence = oSelect
'Get the document
Dim oDoc As Document = oOcc.Definition.Document
'Check the document type If oDoc.DocumentType <> DocumentTypeEnum.kPartDocumentObject Then Exit Sub
'Get the new name
Dim sNN As String = InputBox("Enter new file name:" & vbLf & "(with or without extension)""New file name")
'Handle cancelation and empty input
If sNN = vbNullString Then Exit Sub
'Handle name without extension
If Not sNN.ToUpper.EndsWith(".IPT") Then sNN = sNN & ".ipt"
'Get the document path Dim sFN As String = oDoc.FullFileName Dim iFP As Integer = InStrRev(sFN, "\", -1) sNN = Microsoft.VisualBasic.Left(sFN, iFP) & sNN
'Save under new name oDoc.SaveAs(sNN, True)
'Replace all occurrences in the top assy
oOcc.Replace(sNN, True)
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
Additionally, you can use the Save and Replace component command.
    Sub Main()
        Dim oCmdMgr As CommandManager = ThisApplication.CommandManager
        Dim oSelObj As Object = oCmdMgr.Pick(SelectionFilterEnum.kAssemblyOccurrenceFilter, "Pick part occurrence")
        If oSelObj Is Nothing Then Exit Sub
        Dim oCtrlDefs As ControlDefinitions = oCmdMgr.ControlDefinitions
        oCtrlDefs.Item("AssemblyBonusTools_SaveAndReplaceComponentCmd").Execute()
    End Sub
This will allow more control over file structure too.
