Replace a style in the Part Document using API
Patrick1323
Patrick1323
is there a way to perform this action (replace Style) in the part document, but by code?
JelteDeJong
i could not find a command for Replacing a text style. But i found a way to delete the style and copy the other. it works like this:
Dim originalStyleName As String = "ReplaceMe"
Dim replaceBy As String = "replaceWithMe"
Dim doc As PartDocument = ThisDoc.Document
Dim def As PartComponentDefinition = doc.ComponentDefinition
Dim textStyleOrg As TextStyle = Nothing
Dim textStyleNew As TextStyle = Nothing
For Each style As TextStyle In doc.TextStyles
    If (Style.Name = originalStyleName) Then
        textStyleOrg = Style
    If (Style.Name = replaceBy) Then
        textStyleNew = Style
Next
textStyleOrg.Delete()
textStyleNew.Copy(originalStyleName)
Jelte de Jong
Blog: hjalte.nl - github.com
Patrick1323
Hello JelteDeJong,
thanks for your response, unfortunately I can't delete styles which are in use.
This will throw an exception:
As far as I know there's no way to create a "Standard" like for the drawing styles, and set that new standard as the active one. Then I would be able to delete the old style...
wolfgang_nickl
Hello Patrick1323,
I don't know what you want exatly, but could it be a solution to redefine the Style in Style library as you want and then Update the Stile from Style library?
extStyleOrg.UpdateFromGlobal()
Best Regards
Wolfgang
Patrick1323
Hello Wolfgang,
thats not want to do, I want to delete a style in use.
best regards
Patrick
JelteDeJong
does this work for you:
Dim originalStyleName As String = "Note Text (ANSI) - 3DA"
Dim replaceBy As String = "Sketch Text (ANSI) - 3DA"
Next
' in this part all properties from textStyleNew are copyed to textStyleOrg
Dim type As Type = GetType(Inventor.TextStyle)
For Each prop As Reflection.PropertyInfo In type.GetProperties()
    If (prop.CanWrite) Then
        If (prop.Name = "Name" Or prop.Name = "_Name") Then
            Continue For
        Dim obj = prop.GetValue(textStyleNew)
        prop.SetValue(textStyleOrg, obj)
Next
' both styles are now the same.
Jelte de Jong
