Reorder-Renumber based on part list style
koenroovers
Message 1 of 10
koenroovers
Hello Everyone,
I have got an Ilogic implemented in the drawing template that reorders and renumbers the part list. For assemblies and weldments this works fine. But for mono drawings it doesn't. Can somebody help me with a line of code that checks the part list style and if it is mono then does nothing?
Mono part list style:
Parts List - Mono (Kieu)
Thanks in advance.
Koen
Code is below:
Dim oDrawDoc As DrawingDocument
oDrawDoc = ThisApplication.ActiveDocument
Dim oPartsList1 As PartsList
oPartsList1 = oDrawDoc.ActiveSheet.PartsLists.Item(1)
oPartsList1.Sort("Opmerkingen", 1, "Kodenummer", 1)
oPartsList1.Renumber
Replies (9)
Message 2 of 10
Michael.Navara
You are looking for this?
If oPartsList1.Style.Name = "Parts List - Mono (Kieu)" Then Return
Message 3 of 10
koenroovers
Sadly this is not the solution
Message 4 of 10
Michael.Navara
Message 5 of 10
koenroovers
I receive the following error:
This is the rule i'm using:
Message 6 of 10
Michael.Navara
You need to set oPartsList1 first (Line 5)
Message 7 of 10
koenroovers
@Michael.Navara
Thank you very much, this was the solution!
Message 8 of 10
koenroovers
Hello @Michael.Navara
Is there also a way to perform a check if there is a BOM present before executing the rule?
Sometimes i create drawings without a BOM. And the rule doesn't have to be run in this case.
Message 9 of 10
tyler.warner
@koenroovers you can add a check for the PartsLists.Count:
Dim oSheet As Sheet
oSheet = oDrawDoc.ActiveSheet
If oSheet.PartsLists.Count = 0 Then
	Return
Else
	oPartsList1 = oSheet.PartsLists.Item(1)
	Try
	Catch
	End Try
If this solved your problem or answered your question, please click ACCEPT SOLUTION.
If this helped you, please click LIKE.
Message 10 of 10
koenroovers
Thank you @tyler.warner this worked!
