Batch replace titleblock
morrenengineering
morrenengineering
some of my clients want to have their own titleblock. Then nothing changes to the properties, but to the appearance. I already made some code for this, but it doesn't work. It crashes on the part from line 24 to line 40, while this works in a separate ilogic rule
Sub Main()
	Dim oDoc As Document = ThisDoc.Document
	If MessageBox.Show ( _
		"This will change all title blocks in IDW file for all of the files referenced by this document that have drawings files." _
		& vbLf & "This rule expects that the drawing file shares the same name and location as the component." _
		& vbLf & " " _
		& vbLf & "Are you sure you want to create IDW Drawings for all of the referenced documents?" _
		& vbLf & "This could take a while.", "iLogic  - Batch Output PDFs ",MessageBoxButtons.YesNo) = vbNo Then
		Exit Sub
    '- - - - - - - - - - - - -Component Drawings - - - - - - - - - - - -
	Dim oDrawDoc As DrawingDocument
	Dim oNoDwgString, idwPathName As String
    For Each oRefDoc As Document In oDoc.AllReferencedDocuments
        oBaseName = System.IO.Path.GetFileNameWithoutExtension(oRefDoc.FullFileName)
        oPathAndName = System.IO.Path.GetDirectoryName(oRefDoc.FullFileName) & "\" & oBaseName
        If (System.IO.File.Exists(oPathAndName & ".idw")) Then
			oDrawDoc = ThisApplication.Documents.Open(oPathAndName & ".idw", True)
			'save copy of it to other directory
					Dim doc As DrawingDocument = ThisDoc.Document
					Dim templateFileName As String = "D:\data\Autodesk - Morren\3. Inventor templates\Morrenbv.idw"
					Dim templateDoc As DrawingDocument = ThisApplication.Documents.Open(templateFileName, False)
				' copy your titleblock to original drawing
				Dim templateTitleBloc As TitleBlockDefinition = templateDoc.TitleBlockDefinitions.Item("GL bv")
				Dim newTitleBlok As TitleBlockDefinition = templateTitleBloc.CopyTo(doc, True)
				' close the template document
				templateDoc.Close(True)
				For Each sheet As Sheet In doc.Sheets
				    Dim oldTitleblock As TitleBlock = Sheet.TitleBlock
				    If (oldTitleblock IsNot Nothing) Then
				        oldTitleblock.Delete()
				    Sheet.AddTitleBlock(newTitleBlok)
				Next
			'oDrawDoc.SaveAs(oFolder & oBaseName & ".idw", True)
            oDrawDoc.Close
			oDrawDoc = Nothing
        Else
			idwPathName = oRefDoc.FullFileName
            oNoDwgString = oNoDwgString & vbLf & idwPathName
    Next
    MessageBox.Show("Title blocks are changed")
    MsgBox("Files found without drawings: " & vbLf & oNoDwgString)
End Sub
CCarreiras
Hi!
Autodesk has a tool do to that, why d'ont you use it?
CCarreiras
morrenengineering
Then I have only the information in the file, not the replacement of the title block in the drawing
CCarreiras
This tool is exactly for changing the title block (among other options, borders etc) based on a newly designed title block, including all property fields, and this can be done in a batch by selecting all the files you want change at the same time.
CCarreiras
morrenengineering
I do not want to change the title block, I want to replace the title block
WCrihfield
Hi @morrenengineering.
Within your code, try getting rid of this line of code:
...because you already have a reverence to the drawing document (oDrawDoc).
Then find/replace all following uses of the 'doc' variable with 'oDrawDoc' instead.
Change:
to
Dim newTitleBlok As TitleBlockDefinition = templateTitleBloc.CopyTo(oDrawDoc, True)
Change:
to
For Each sheet As Sheet In oDrawDoc.Sheets
...and un-comment out your SaveAs line, because it is already using the oDrawDoc variable.
Just my thoughts based on what I see.
Wesley Crihfield
(Not an Autodesk Employee)
JelteDeJong
I think that you can use the method that @CCarreiras proposes but you will need to select the files your self 😉 But if you want to do it a bit more automated way...
I did have a look at your rule. (I could not test it by the way) I found some points.
The template file is opened and closed a lot. I moved those actions outside the loop.
On line 23 I found "ThisDoc.Document" I found that strange and I believe you need to use the object "oDrawDoc".
I have added some try/catch blocks so if something goes wrong you can tell us where 😉
Try this rule:
If MessageBox.Show(
		& vbLf & " " _
		& vbLf & "This could take a while.", "iLogic  - Batch Output PDFs ", MessageBoxButtons.YesNo) = vbNo Then
    Exit Sub
    Dim oBaseName = System.IO.Path.GetFileNameWithoutExtension(oRefDoc.FullFileName)
    Dim oPathAndName = System.IO.Path.GetDirectoryName(oRefDoc.FullFileName) & "\" & oBaseName
        Try
            newTitleBlok = templateTitleBloc.CopyTo(oDrawDoc, True)
        Catch ex As Exception
            MsgBox("Something went wrong while copy TitleBlockDefinition to file: " & oDrawDoc.FullFileName)
        End Try
            Try
                MsgBox(String.Format("something went wrong on sheet '{0}' in file '{1}'",
                                     Sheet.Name, oDrawDoc.FullFileName))
            End Try
        Next
        oDrawDoc.Close()
        oDrawDoc = Nothing
    Else
Next
Jelte de Jong
Blog: hjalte.nl - github.com
