- Mute
- Permalink
- Report
Hi all,
I used the modified version of this rule, posted here:
Renumber Balloons for iLogic
for some testing reasons. If an assembly contains a subassemby, the following message appears:
System.InvalidCastException: Unable to cast COM object of type 'System.__ComObject' to interface type 'Inventor.PartComponentDefinition'. This operation failed because the QueryInterface call on the COM component for the interface with IID '{DA33F1A3-7C3F-11D3-B794-0060B0F159EF}' failed due to the following error: Schnittstelle nicht unterstützt (Exception from HRESULT: 0x80004002 (E_NOINTERFACE)).
at LmiRuleScript.Main()
at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
at p.b(String A_0)
Does anyone have a suggestion or the same problem or better a solution for it?
All I want to achieve is that this code renumbers separate part (current situation) and assembly files against the assembly BOM.
Thanks in advance.
