Renaming sketch variable (by selecting them from the sketch)
RoyWickrama_RWEI
Advisor Advisor
RoyWickrama_RWEI
With I started to doing with iLogic, I keep getting more and more problems (or needs). To go through my modelling at hand, I need to rename sketch variables as they need. Using an ilogic, is there a way to pick these required variables from the sketch and then to rename (in a text box available) one by one?
Please help. Thanks
rjay75
This will rename a sketch dimension.
1. Select the dimension.
2. Run the rule
Rule Code:
Dim oSelect As SelectSet
oSelect = ThisApplication.ActiveDocument.SelectSet
If oSelect.Count = 1 Then
    sd = oSelect(1)
    If TypeOf sd Is DimensionConstraint Then
        newName = InputBox("Enter New Name:", "Rename Dimension", sd.Parameter.Name).Trim()
        If Not String.IsNullOrEmpty(newName) Then
            sd.Parameter.Name = newName
        End If
    End If
End If
RoyWickrama_RWEI
I am sorry: I missed to accept this as solution before!
