Renaming selected Part parameters & set to export from Assembly level
andrew.tom.reynolds
andrew.tom.reynolds
I'm trying to rename a parameter "d2" from a number of selected parts in an Assembly to "LENGTH" and then set to export with a custom property format so I can use it in a BoM export later.
I've gleaned as much as i can from other posts and i'm 99% there. I'm just not sure how to dig in to the selected occurrence parameters properly. Below is my current code. I'm using the same selection structure for another rule and it's working fine. It's just the parameters section i'm not getting right.
Can anyone correct me please?
'Description of the Rule and if you want to continue
 Result = MessageBox.Show("Do you want to continue?" _
& vbNewLine &"" _
& vbNewLine & "This rule allows you to browse the tree and select multiple items,then press the Esc Key and have an action carried out" _
& vbNewLine & "", "Browse And Select" _
, MessageBoxButtons.YesNoCancel, MessageBoxIcon.Exclamation, MessageBoxDefaultButton.Button2)
If Result = vbNo Then
	MessageBox.Show ("Rule Canceled Exiting", "Title")
ElseIf Result = vbYes Then
	Dim oDoc As AssemblyDocument
	oDoc = ThisDoc.Document
	oCompDef = oDoc.ComponentDefinition
	Dim oSet As HighlightSet
	oSet = oDoc.CreateHighlightSet
	'MessageBox.Show ("Rule will Run", "Title")
	'[Pick Assembly Occurrences
	Dim comps As ObjectCollection
	Dim comp As Object
	comps = ThisApplication.TransientObjects.CreateObjectCollection
	While True
		comp = ThisApplication.CommandManager.Pick(
			SelectionFilterEnum.kAssemblyLeafOccurrenceFilter,
			"Select a component")
		' If nothing gets selected then we're done
		If IsNothing(comp) Then Exit While
			comps.Add(comp)
			oSet.AddItem(comp)
	End While
	Result = MessageBox.Show("Do you want to process all Selected?", "Process selected files", MessageBoxButtons.YesNoCancel, MessageBoxIcon.Exclamation, MessageBoxDefaultButton.Button2)
	MessageBox.Show ("Rule Cancelled", "iLogic")
	'If there are selected Components we can Do something
		For Each comp In comps
			'Pick only parts
			If comp.DefinitionDocumentType = kPartDocumentObject Then
				'Get document of each occurrence
				Dim oOccDoc As Document
				oOccDoc = comp.Definition.Document
				oOccDoc.Parameter("d2").Name = "LENGTH"
				oOccDoc.Parameter("LENGTH").ExposedAsProperty = True
				oOccDoc.Parameter("LENGTH").CustomPropertyFormat.ShowUnitsString = False
				oOccDoc.Parameter("LENGTH").CustomPropertyFormat.Precision = "0"
			End If
		Next
	MessageBox.Show("Files Processed", "iLogic")
	'Clear Highlighting
	oSet.Clear()
	End If
End If
Zach.Stauffer
The Parameters object is actually on the PartComponentDefinition, not the PartDocument, so you should just be able to use "comp.Definition" directly if it is the correct type.
A.Acheson
Another thing it looks like you are using "parameters.item" incorrectly.
Syntax
Parameters.Item( Index As Variant ) As Parameter
https://help.autodesk.com/view/INVNTOR/2021/ENU/?guid=GUID-9031D871-3BAE-4170-8F69-4E49B23336CD
Regards
Alan
andrew.tom.reynolds
Thanks for the info, but sadly my knowledge is very basic. Can someone please correct what i've done here?
			'Pick only parts
				'Dim oOccDoc As Document
				oOccDoc.Parameters.Item("d2").Name = "LENGTH"
				oOccDoc.Parameters.Item("LENGTH").ExposedAsProperty = True
				oOccDoc.Parameters.Item("LENGTH").CustomPropertyFormat.ShowUnitsString = False
				oOccDoc.Parameters.Item("LENGTH").CustomPropertyFormat.Precision = "0"
			End If
		Next
A.Acheson
So in short you have not accessed the location of where the parameters are reached from. This is shown in the error message. If you look at the API help for a document you will see no reference to parameters.
Looking at the API sample for the parameters collection you will see that you can access the collection from all of the below objects.
Accessed From
AssemblyComponentDefinition.Parameters, DrawingDocument.Parameters, FlatPattern.Parameters, PartComponentDefinition.Parameters, SheetMetalComponentDefinition.Parameters, WeldmentComponentDefinition.Parameters
So to this now leaves you with the object you have the occurrence and where you want to get to the parameters collection. If we look at API sample for the occurrence you will find a definition object which is a generic type.  Next you may want to only return/work with part documents so we will use the ComponentOccurrence.DefinitionDocumentType As ObjectTypeEnum to filter the part documents  or alternately you could use ComponentDefinition.Type() As DocumentTypeEnum to filter the definition type.
@Zach.Stauffer refers to this earlier in the thread.
Here is the working rule.
& vbNewLine &"" _
	Dim comp As Object
	While True
			comps.Add(comp)
			oSet.AddItem(comp)
	End While
			'Work with only parts
			If comp.DefinitionDocumentType = DocumentTypeEnum.kPartDocumentObject Then
				Dim oPartDef As PartComponentDefinition = comp.Definition
				Dim oParameters As Parameters = oPartDef.Parameters
				Try
				oParameters("d2").Name = "LENGTH"
				oParameters("LENGTH").ExposedAsProperty = True
				oParameters("LENGTH").CustomPropertyFormat.ShowUnitsString = False
				oParameters("LENGTH").CustomPropertyFormat.Precision = "0"
				Catch
					MessageBox.Show("Error Getting Parameter", "iLogic")
				End Try
			Else
				MessageBox.Show("Another document type has being chosen", "iLogic")
			End If
		Next
	'Clear Highlighting
	oSet.Clear()
	End If
End If
Regards
Alan
andrew.tom.reynolds
Thanks @A.Acheson that works and great explanation.
The only thing I had to change to make it perfect was
Should actually be = kZeroDecimalPlacePrecision
Cheers!
