rename or saveas?
rename or saveas?
martinhoos
Message 1 of 13
rename or saveas?
martinhoos
Hello Forum,
i have a IAM (master.iam) and a IDW (master.idw), both with scripts, that means i can change the IAM with iLogic after this i save the IAM and open the IDW with automatic ilogic (runs after open). My wish is, to rename or saveas the IAM and the IDW via iLogic. I dont know how, pls can you help?
Regards
Martin
Replies (12)
Message 2 of 13
Owner2229
Hey, do you want to "save as" only the top assembly file or also all sub-assemblies and sub-parts?
Here's the simple code (without any inputs, error catching, exceptions etc.).
It will re-save ONLY the top file.
Dim oDoc As Document = ThisApplication.ActiveDocument
Dim oNewName As String = "C:\NewPath\NewName"
Dim Ext As String = vbNullString
Select Case oDoc.DocumentType
Case DocumentTypeEnum.kPartDocumentObject:      Ext = ".ipt"
Case DocumentTypeEnum.kAssemblyDocumentObject:  Ext = ".iam"
Case DocumentTypeEnum.kDrawingDocumentObject:   Ext = ".idw"
Case Else: Exit Sub
End Select
oNewName = oNewName & Ext
oDoc.SaveAs(oNewName, True)
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
Message 3 of 13
martinhoos
Hi Mike,
thanks a lot...
i like to rename only the top assembly and the top drawing.
With your code the new idw is still looking for the old assembly (master.iam). Is it posible to "save as" or "rename" the idw and automaticly the iam? Hard to explain ...
Regards Martin
Message 4 of 13
Owner2229
I know what you mean. Does the IDW and IAM by any chance have the same name? Like:
MyAwesomeAssembly.iam
MyAwesomeAssembly.idw
Also, would you like to run the rule from the assembly or from the drawing?
Note:
The drawing knows exactly the location and name of the assembly.
If run from the assembly, the rule will have to guess the drawing's name and look for it.
Mike
Message 5 of 13
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi Martin,
Please try the following sample code in master.idw (DrawingDocument).
	Dim drawingDoc As DrawingDocument
        drawingDoc = mApp.ActiveDocument
        drawingDoc.SaveAs("NewPath\new_master.idw", False)
        Dim oSheet As Sheet
        oSheet = drawingDoc.Sheets.Item(1)
        Dim oView As DrawingView
        oView = oSheet.DrawingViews.Item(1)
        Dim assyDoc As AssemblyDocument
        assyDoc = oView.ReferencedDocumentDescriptor.ReferencedDocument
        assyDoc.SaveAs("NewPath\new_master.iam", False)
Please feel free to contact if there is any doubt.
If solves your problem, click on "Accept as solution" / give a "kudo"
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Message 6 of 13
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi Martin,
Oops...Previous code was in VB.net.
Please find the iLogic code in the following. This code need to run in IDW(master.idw).
    drawingDoc = ThisApplication.ActiveDocument
    Dim oSheet As Sheet
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 7 of 13
martinhoos
Hi Mike,
the way i like to do this:
1. copy the master.iam and the master.idw to an new Folder.
2. make changes with scipting in the iam and also in the idw.
3. rename the iam and the idw, so that the new idw is looking for the new iam
To answer your question, yes, both have the same Name: "master"
I like to run the rule from the idw.
Thank you very much.
Regards
Martin
Message 8 of 13
Owner2229
Here you go. You can run it from drawing, assembly or part. It should handle it all.
Sub Main()
	Dim oFD As FileDialog
	Call ThisApplication.CreateFileDialog(oFD)
	oFD.Filter = "Inventor Files (*.idw;*.iam;*.ipt)|*.idw;*.iam;*.ipt"
	oFD.FilterIndex = 1
	oFD.DialogTitle = "Select folder and new filename for new drawing / assembly / file."
	oFD.InitialDirectory = oDoc.FullFileName
	oFD.ShowSave()
	Dim oNewName As String = oFD.FileName
	If oNewName = vbNullString Then Exit Sub
	Dim FNP As Integer = InStrRev(oNewName, ".", -1)
	oNewName = Left(oNewName, FNP)
	If oDoc.DocumentType = DocumentTypeEnum.kDrawingDocumentObject Then
		FromDrawing(oDoc, oNewName)
	Else
		FromPart(oDoc, oNewName)
	End If
End Sub
Sub FromDrawing(oDoc As DrawingDocument, oNewName As String)
	Dim oSheet As Sheet = oDoc.Sheets.Item(1)
	Dim pNewName As String = vbNullString
	If oSheet.DrawingViews.Count > 0 Then
		Dim oView As DrawingView = oSheet.DrawingViews.Item(1)
		Dim pDoc As Document = oView.ReferencedDocumentDescriptor.ReferencedDocument
		pNewName = SavePart(pDoc, oNewName)
	End If
	SaveDrawing(oDoc, oNewName, pNewName)
End Sub
Sub FromPart(oDoc As DrawingDocument, oNewName As String)
	Dim OldName As String = oDoc.FullFileName
	Dim pNewName As String = SavePart(oDoc, oNewName)
	Dim FNP As Integer = InStrRev(OldName, ".", -1)
	OldName = Left(OldName, FNP) & "idw"
	Dim pDoc As DrawingDocument = ThisApplication.Documents.Open(OldName, True)
	SaveDrawing(pDoc, oNewName, pNewName)
End Sub
Function SavePart(oDoc As DrawingDocument, oNewName As String) As String
	Dim Ext As String = GetExt(oDoc)
	If Ext = vbNullString Then Return vbNullString
	Dim NewName As String = NewName & Ext
	oDoc.SaveAs(NewName, False)
	Return NewName
End Function
Sub SaveDrawing(oDoc As DrawingDocument, oNewName As String, pNewName As String)
	Dim NewName As String = NewName & "idw"
	oDoc.Close(True)
	If pNewName = vbNullString Then Exit Sub
	Dim nDoc As DrawingDocument = ThisApplication.Documents.Open(NewName, True)
	Dim oRefFile As Inventor.FileDescriptor = nDoc.File.ReferencedFileDescriptors(1)
	Try
		oRefFile.ReplaceReference(pNewName)
	Catch
	End Try
	nDoc.Save()
End Sub
Function GetExt(oDoc As Document) As String
	Case DocumentTypeEnum.kPartDocumentObject:	Return "ipt"
	Case DocumentTypeEnum.kAssemblyDocumentObject:	Return "iam"
	End Select
	Return vbNullString
End Function
Mike
Message 9 of 13
martinhoos
Hi Mike,
i get a message, may be i made a mistake.
I copied your code in a iLogic rule (IDW) and after it runs i get this message:
Thanks for your help!
Regards
Martin
Message 10 of 13
Owner2229
I had to fix a couple of typos, but now it should be working:
Sub Main()
	oFD.FilterIndex = 1
	oFD.ShowSave()
	If FNP > 0 And FNP > Len(oNewName) - 4 Then
	Else
		oNewName = oNewName & "."
	End If
	Else
	End If
End Sub
		pDoc.Close(True)
	End If
End Sub
Sub FromPart(oDoc As Document, oNewName As String)
End Sub
Function SavePart(oDoc As Document, oNewName As String) As String
	Dim NewName As String = oNewName & Ext
	oDoc.SaveAs(NewName, True)
	Return NewName
End Function
	Dim NewName As String = oNewName & "idw"
	oDoc.Close(True)
	Try
	Catch
	End Try
	nDoc.Save()
End Sub
	End Select
	Return vbNullString
End Function
Mike
Message 11 of 13
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi Martin,
The above requirement can be achieved by the following sample code. It should run in Master.idw.
Dim oDrawingDoc as DrawingDocument
oDrawingDoc = ThisApplication.ActiveDocument
Dim NewPath As String = "C:\Temp\"
Dim NewName As String = "NewMaster"
Dim currentFile As String = ThisDoc.PathAndFileName(False)
Dim assyDoc as AssemblyDocument
assyDoc = ThisApplication.Documents.Open(currentFile & ".iam")
assyDoc.SaveAs(NewPath & NewName & ".iam",False)
assyDoc.Close()
oDrawingDoc.SaveAs(NewPath & NewName & ".idw",False)
Dim oFD As FileDescriptor
oFD = oDrawingDoc.ReferencedFileDescriptors(1).DocumentDescriptor.ReferencedFileDescriptor
oFD.ReplaceReference(NewPath & NewName & ".iam")
oDrawingDoc.Update()
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 12 of 13
martinhoos
Thank you very much, Mike and Chandra, for your help!
Regards Martin
Message 13 of 13
nivyus
Hello, this is awesome. It is possible to reoptimize and reassemble the IAM or idw layer by layer to facilitate modification (read the iproperty stock number in Ipt/iam as the filename) and delete the old Idw/ipt/iam. Thank you
