Rename Model View to its View Cube Orientation
C_Haines_ENG
Message 1 of 11
C_Haines_ENG
I would like to be able to click on an a model view at it will rename the models label to its current view cube orientation.
So if you're looking at the top view it will rename the model to "Top".
I'm not entirely sure if this is even possible but it would save my fingers from getting carpel tunnel haha.
Replies (10)
Message 2 of 11
A.Acheson
Here is a post on how to do the whole sheet.
If you want to do a single selection then use the pick function and change the SelectionFilterEnum to kDrawingViewFilter
Ensure to remove the for loop for the views.
CommandManager.PickFilter As SelectionFilterEnumPromptText As String ) As Object
Regards
Alan
Message 3 of 11
C_Haines_ENG
I'm getting a "Object reference not set to an instance of an object." every time I try to close the tool
Dim tmpSheet As Sheet = ThisDrawing.ActiveSheet.Sheet
Dim tmpView As DrawingView
For Each tmpView In tmpSheet.DrawingViews
    Dim myDrawingViewName As String = ""
	tmpView = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingViewFilter, "Select a face")
        Select Case tmpView.Camera.ViewOrientationType
            Case ViewOrientationTypeEnum.kBackViewOrientation
                myDrawingViewName = "BACK"
            Case ViewOrientationTypeEnum.kBottomViewOrientation
                myDrawingViewName = "BOTTOM"
            Case ViewOrientationTypeEnum.kFrontViewOrientation
                myDrawingViewName = "FRONT"
            Case ViewOrientationTypeEnum.kIsoBottomLeftViewOrientation
                myDrawingViewName = "ISOMETRIC"
            Case ViewOrientationTypeEnum.kIsoBottomRightViewOrientation
            Case ViewOrientationTypeEnum.kIsoTopLeftViewOrientation
            Case ViewOrientationTypeEnum.kIsoTopRightViewOrientation
            Case ViewOrientationTypeEnum.kLeftViewOrientation
                myDrawingViewName = "SIDE"
            Case ViewOrientationTypeEnum.kRightViewOrientation
            Case ViewOrientationTypeEnum.kTopViewOrientation
                myDrawingViewName = "TOP"
            Case Else
                myDrawingViewName = ""
            End Select
        If Not myDrawingViewName = "" Then
            tmpView.Name = myDrawingViewName
		If tmpView.IsFlatPatternView =True Then
           tmpView.Name = "FLAT PATTERN"
Next
.Im assuming this is because of the looping function but I need to be able to select multiple views at once.
Message 4 of 11
JelteDeJong
This version will let you select views till you hit escape.
Do
    Dim tmpView As DrawingView = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingViewFilter, "Select a view")
    If (tmpView Is Nothing) Then Exit Do
        Case Else
    End Select
    If tmpView.IsFlatPatternView = True Then
Loop
Jelte de Jong
Blog: hjalte.nl - github.com
Message 5 of 11
C_Haines_ENG
Why cant I delete comments...
Message 6 of 11
GosponZ
JelteDeJong It would be nice if label toggle is on and not to show scale when pick a view. Can you do that please.
Message 7 of 11
C_Haines_ENG
Is it possible for the loop to only effect views with the views listed in the code such as "Top" "Front", etc.
I don't want it to overwrite custom view labels every time it runs.
Message 8 of 11
GosponZ
Still looking..
Message 9 of 11
C_Haines_ENG
As for not showing scale I think that comes down to your Style Library in the Standards section. You can change the default label for your drawing views.
As for toggling labels, you could add
oView.ShowLabel = True
 to the code above.
Message 10 of 11
GosponZ
I tried but no working
Message 11 of 11
C_Haines_ENG
Is there a way to account for rotation of a view?
