Drawing View Labels
Drawing View Labels
Message 1 of 8
Drawing View Labels
Hi, I am using Inventor 2021 and using the ilogic rule below to populate the View Labels on my Drawings as per the View Cube and it works well.
Dim tmpSheet As Sheet = ThisDrawing.ActiveSheet.Sheet
Dim tmpView As DrawingView
For Each tmpView In tmpSheet.DrawingViews
    Dim myDrawingViewName As String = ""
	If tmpView.Type = ObjectTypeEnum.kDrawingViewObject Then
        Select Case tmpView.Camera.ViewOrientationType
            Case ViewOrientationTypeEnum.kBackViewOrientation
                myDrawingViewName = "BACK VIEW"
            Case ViewOrientationTypeEnum.kBottomViewOrientation
                myDrawingViewName = "BOTTOM VIEW"
            Case ViewOrientationTypeEnum.kFrontViewOrientation
                myDrawingViewName = "FRONT VIEW"
            Case ViewOrientationTypeEnum.kIsoBottomLeftViewOrientation
                myDrawingViewName = "ISOMETRIC VIEW"
            Case ViewOrientationTypeEnum.kIsoBottomRightViewOrientation
            Case ViewOrientationTypeEnum.kIsoTopLeftViewOrientation
            Case ViewOrientationTypeEnum.kIsoTopRightViewOrientation
            Case ViewOrientationTypeEnum.kLeftViewOrientation
                myDrawingViewName = "SIDE VIEW"
            Case ViewOrientationTypeEnum.kRightViewOrientation
            Case ViewOrientationTypeEnum.kTopViewOrientation
                myDrawingViewName = "TOP VIEW"
            Case Else
                myDrawingViewName = ""
            End Select
        If Not myDrawingViewName = "" Then
            tmpView.Name = myDrawingViewName
        End If
		If tmpView.IsFlatPatternView =True Then
           tmpView.Name = "FLAT PATTERN"
        End If
    End If
Next
The problem I have is if I place a base view in a rotated orientation, it does not  update the View label. See below
Base view on Left in default orientation, Base view on Right Rotated 90deg on view placement.
Any help with editing this rule to allow for rotated views to populate the view label will be much appreciated. Thanks
Replies (7)
Message 2 of 8
Ralf_Krieg
Hello
The tmpView.Camera.ViewOrientationType for rotated views is always kArbitraryViewOrientation. The rotation in radiant of the drawing view is a double value in tmpView.Rotation. If you save this value in a variable and set this value to 0, the Camera.ViewOrientationType is the value you need. Rotate back by assigning the variable value to back to Camera.Rotation property. Or, start a transaction before rotating and abort this transaction after your select case and before assigning myDrawingViewName value to tmpView.Name. The value of variable myDrawingViewName is not deleted on transaction abort.
R. Krieg
RKW Solutions
www.rkw-solutions.com
Message 3 of 8
Hi Thanks for the reply.
I am somewhat new to ilogic and am unsure how to apply what you outlined to the existing rule to allow for the rotated 'FRONT VIEW' drawing view label to be populated as 'FRONT VIEW'.  I understand that rotated views are always kArbitraryViewOrientation & I understand the rotation in radians (eg tmpView.Rotation = 90*PI / 180) but am unsure how to save this value in a variable and set this value to 0?
Any addidtional assistance you can provide would be much appreciated.
Message 4 of 8
Ralf_Krieg
Hello
I've added the transaction things I described above to the script. The advantage is, as we abort the transaction later, everything we modified is rolled back automatically by Inventor. It's like nothing of it ever happened. 🙂
		'Encapsulat the rotation of drawing view in a transaction
		Dim oTrans As Transaction
		oTrans = ThisApplication.TransactionManager.StartTransaction(ThisDrawing.Document, "Rotate Drawing View temp")
		' Set rotation to 0
		If tmpView.Camera.ViewOrientationType = ViewOrientationTypeEnum.kArbitraryViewOrientation Then
			tmpView.Rotation = 0
    	End If
            Case Else
            End Select
		' Abort the transaction so everything is rolled back like before the transaction starts
		oTrans.Abort
        End If
        End If
    End If
Next
R. Krieg
RKW Solutions
Message 5 of 8
WCrihfield
Hi @Anonymous .
I worked on a very similar post before, a couple years ago I think, and I created a very short iLogic rule to rename all drawing views according to their view orientation type.  It basically used the ViewOrientationTypeEnum's string value and got rid of the starting "k" and the ending "ViewOrientation" text, and used the remaining descriptive text to name the view, all in upper case.  Although it doesn't attempt to solve your problem, I thought you might find it interesting, since it is related, and very efficient.
Here's the code:
Dim oDoc As DrawingDocument = ThisDrawing.Document
Dim oViews As DrawingViews
Dim oOrientType As ViewOrientationTypeEnum
Dim oOrigViewName As String
Dim oNewViewName As String
For Each oSheet As Sheet In oDoc.Sheets
	oViews = oSheet.DrawingViews
	For Each oView As DrawingView In oViews
		oOrientType = oView.Camera.ViewOrientationType
		oOrigViewName = oView.Name
		oNewViewName = Mid(oOrientType.ToString, 2, Len(oOrientType.ToString) -16)
		oView.ShowLabel = True
		oView.Name = oNewViewName.ToUpper
	Next
Next
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Or, if this helped you, please click (LIKE or KUDOS) 👍.
Wesley Crihfield
(Not an Autodesk Employee)
Message 6 of 8
Hi, thanks for writing that into the script. I tested it and it works for a view rotated after placement but does not work for a view that is placed in a rotated orientation. Is there a way to make it work for both types of rotated views?
Also I got an error in the rule when I had an Auxiliary View that had the alignment broken. Any idea why that would be? See below image.
Message 7 of 8
Ralf_Krieg
Hello
I found no solution to rotate back base views that are rotatet on placement. Maybe it's possible to rotate this drawing views stepwise 90° and check drawingviewtype after each step. This would only work if the user has not rotate a free angle or rotate free in orbit. I think we've nearly reached the limit of automation.
I think the error message appears as we try to rotate back a not rotated view. I've modified the code to rotate onle if drawingview rotation is not 0.
			' Set rotation to 0
				If tmpView.Rotation<>0 Then
				End If
	    	End If
	            Case Else
	            End Select
			oTrans.Abort
	        End If
	        End If
	    End If
Next
R. Krieg
RKW Solutions
Message 8 of 8
No worries at all, I can definitely live with it the way it works now. Your efforts in helping me make it work better are very much appreciated.
