Rename browser node for component pattern
bhavik4244
bhavik4244
Hi there,
I need to rename browser node for component pattern, first parent part will be manully changed browser name but for later ones I need auto renaming of browser name accoding to the numbering sequencing. You can find it how I need in below snap.
pattern can varies from 3 or 4 or 5. I have attached the Inventor files also.
thanks a lot!
Bhavik Suthar
JhoelForshav
Hi @bhavik4244
Running this iLogic rule in your attached assembly will give you the result you want according to your picture 🙂
Dim oAsm As AssemblyDocument = ThisDoc.Document
Dim oPattern As OccurrencePattern = oAsm.ComponentDefinition.OccurrencePatterns(1)
For i = 1 To oPattern.OccurrencePatternElements.Count
	Dim n As Integer = 1
	For Each oOcc As ComponentOccurrence In oPattern.OccurrencePatternElements(i).Occurrences
		oOcc.Name = i & n.ToString("00")
		n += 1
	Next
Next
bhavik4244
@JhoelForshav
Thank you so much, this what I exactly want 😊
Bhavik Suthar
bhavik4244
@JhoelForshav
I need your help Jhoel, I need to change second letter from right which is 1. It can be 2,3,4 or 5. other need to be constant.
Thank again.
Bhavik Suthar
