Remote Server Errors
dbrblg
Message 1 of 1
dbrblg
Has anyone suffered from run-time error 462 'the remote server machine does not exist or is unavailable' when using Access vba?
I am using access vba to open many assembly files to update them and then save them.  The code gets a list of assemblies from a database and iterates through each one opening them up, updating and finally saving then closing the document.
After an indeterminate number of assemblies, Inventor suddenly shuts down and gives me the error above.
I have included the code I am using below:
Dim rs As ADODB.Recordset
    Dim cn As ADODB.Connection
    Dim cm As ADODB.Command
    Dim InvAppDoc As Inventor.AssemblyDocument
    Dim i As Long
    i = 0
    If (InvApp Is Nothing) Then
        Set InvApp = StartInventor()
    End If
    Set cn = New ADODB.Connection
    Set cn = CurrentProject.Connection
    Set rs = New ADODB.Recordset
    rs.CursorLocation = adUseClient
    Set cm = New ADODB.Command
    cm.ActiveConnection = cn
    cm.Parameters.Append cm.CreateParameter("@FileLinksChecked", adBoolean, adParamInput, 1, 0)
    cm.Parameters.Append cm.CreateParameter("@FileExtension", adWChar, adParamInput, Len("iam"), "iam")
    If (lngCount <> 0) Then
        cm.CommandText = "SELECT TOP " & lngCount & " FullPath FROM InventorFiles WHERE (FileLinksChecked=@FileLinksChecked AND FileExtension=@FileExtension);"
    Else
        cm.CommandText = "SELECT FullPath FROM InventorFiles WHERE (FileLinksChecked=@FileLinksChecked AND FileExtension=@FileExtension);"
    End If
    Set rs = cm.Execute
    Do Until (rs.EOF Or bCancel)
        If (GetAttr(rs.Fields("FullPath").Value) And vbReadOnly) Then
            Call SetAttr(rs.Fields("FullPath").Value, 0)
        End If
        Set InvAppDoc = InvApp.Documents.Open(rs.Fields("FullPath").Value)
        Call InvAppDoc.Update2(True)
        Call InvAppDoc.Save2(True)
        Call InvApp.ActiveDocument.Close(False)
        Call UpdateInventorFileAsChecked(rs.Fields("FullPath").Value)
        rs.MoveNext
    loop
    InvApp.Quit
    Set InvApp = Nothing
    Set InvAppDoc = Nothing
Does anyone know why this is being caused?
Replies (0)
