Reg : Unknown Error while IDW --> DWG
naresh_kalyan
naresh_kalyan
Dear all,
I'm geting Error "Invalid Procedure call or orgument"
and when I hit debug and then hit Continue, it's working fine. Please, Can anyone fix this.
sFname = odoc.FullFileName
sFname = Left$(sFname, Len(sFname) - 3) & "dwg"
Call odoc.SaveAs(sFname, True)' ERROR line
Thanks in advance.
NKalyan
Does saving to DWG via the 'Save Copy As' command in Inventor generate any
errors? If not, could you post the data set and the code?
Sanjay-
wrote in message news:5583314@discussion.autodesk.com...
Dear all,
anyone fix this.
Thanks in advance.
NKalyan
naresh_kalyan
Thanks for the reply... Sanjay. Here is the total code.
Private Sub Command2_Click()
Dim iapp As inventor.Application
Dim odoc As inventor.Document
Dim sFname As String
Set iapp = CreateObject("Inventor.application")
iapp.SilentOperation = True
Set odoc = iapp.Documents.Open("D:\SG422RPN\SG422RPN-DRAWINGS.idw", True)
On Error Resume Next
MsgBox "Finished"
End Sub
I don't see any obvious problems with the code. I'd recommend that you try
the following:
1. Make sure the 'Save Copy As' works fine via the user interface.
2. Add the following 2 lines of code after the Documents.Open call below:
odoc.Views.Item(1).Update
DoEvents
3. Try the code with other drawings.
If you still can't get it to work, we will need the dataset you are working
with so we can investigate the issue.
Sanjay-
wrote in message news:5584694@discussion.autodesk.com...
MsgBox "Finished"
End Sub
naresh_kalyan
No Progress.. still same Error.
I dont know about "DATASET". could you plz tell me what it is?
But, atleast... I found why it is happening.
If in "Windows Task Manager", is there any "Inventor.Exe" still running even if I close Inventor.... then the code returning with Error.
If I End the Task manually and run the code, then there is no error.
naresh_kalyan
Sanjay.... can u plz tell me what is a DATASET ?
The Inventor documents that you are working with. If you can post those
files, we can try to reproduce the issue here.
Sanjay-
wrote in message news:5605626@discussion.autodesk.com...
