Refresh Global Forms
a81383
a81383
Good afternoon,
I'm looking to automate the refresh of global forms (See Image Below). Would someone be willing to help me out with this?
Thank you for your time!
WCrihfield
Interesting, I don't think I have ever used that before.  And there is no tool tip info when you hover it either, so I am not even sure what it is supposed to do.  Maybe if you renamed some of the forms, or moved them around and they were not showing correctly in the tab anymore, this would fix that?  I searched for any 'commands' that contained "refresh", and there were only 5 (in Inventor 2024), and none of them seemed like the right one for this.  There are also several iLogic specific commands, but none of them seemed like they were for this purpose either.  This may simply not be exposed to the API or to any known iLogic interactions yet.
Wesley Crihfield
(Not an Autodesk Employee)
a81383
Thank you for looking into this @WCrihfield. That is correct the forms are no longer showing up after a recent transition and the refresh brings them back. Given that it's a simply process, I'll accept no-solution as my solution for this one. Thanks again!
