ReferenceKeyManager or AttributeManager
wmgshurik
wmgshurik
How can I get  ComponentOccurence object back faster, using ReferenceKeyManager or AttributeManager?
If you need a persistent solution, you should utilize both methods. Instead of bothering with converting your reference key byte arrays into strings for use, save them directly into attributes then use the attribute value to bind back to an object.
