Clear all appearance overrides in part with ilogic?
Message 1 of 19
Hey,
I have a very big list of parts, all these parts need their appearance overrides cleared. I've tried the solution in this thread, but it didn't work (no overrides were deleted).
Thanks in advance
Stijn
Replies (18)
Message 2 of 19
Jef_E
So, correct me if i'm wrong you want to clear the override for all parts / assemblies from the top assembly level?
Please kudo if this post was helpfull
Please accept as solution if your problem was solved
Inventor 2014 SP2
Message 3 of 19
No there is no assembly,
It's just a lot of seperate parts in a folder. They are not linked to eachother. I want to write a rule that does it for me.
Message 4 of 19
Jef_E
Okay, I created a small iLogic rule that does this for you, you just need to point it too the right directory, change the value marked in red.
To run the rule create a empty part file, create a new iLogic rule and paste the code. Adjust the text marked in red and your ready.
Imports System.IO
Sub Main
' Set the directory
Dim oDirectoryPath As String
oDirectoryPath = "C:\Temp\"
' Get the directory info
Dim oDirectoryInfo As New DirectoryInfo(oDirectoryPath)
' Create collection to hold all part files from the directory
Dim oFiles As IO.FileInfo()
oFiles = oDirectoryInfo.GetFiles("*ipt")
' Set a counter for the end message
Dim oCount As Integer = 0
' Set reference to the inventor documents
Dim oDocs As Documents
oDocs = ThisApplication.Documents
' Loop all the files
For Each oFile As FileInfo In oFiles
	' Set reference to the file
	Dim oDoc As PartDocument
	oDoc = oDocs.Open(oFile.FullName, True)
	' Set the appearance Source Type
	oDoc.AppearanceSourceType = AppearanceSourceTypeEnum.kMaterialAppearance
	' Save the document
	oDoc.Save
	' Close the document
	oDoc.Close
	' Add to the counter
	oCount += 1
Next
' Finish message
MsgBox("Number of files processed = " & oCount)
End Sub
Sorry if I spoiled the fun of writing the code yourself? It seemed to me you were asking more for a solution than help writing the code. ( correct me if i'm wrong )
NOTE this code only works for part files that have read/write permissions ( so files checked-in into vault will cause an error, if the files are vaulted please check them out before running the code )
Inventor 2014 SP2
Message 5 of 19
Wow, thank you for the quick and extensive reply, you helped me alot already.
The rule runs fine and opens and closes every part, but the overrides are not deleted.
I'm sorry but there is one thing that I forgot to add, that might cause the problem; The files are not part files (ipt), but ".IGS" files. I changed the "*ipt" to "*IGS" but the overrides are not being deleted.
Message 6 of 19
Just for testing puposes, I opened and saved some of the files as ipt, and tried to run the original rule. It didnt delete the overrides. So apparently the fact that the files are IGS doesnt matter.
This is what I mean by clearing/deleting the appearance overrides:
Then I click "Select all" --> "Ok"
Message 7 of 19
Jef_E
Well... thats just wow.. you speak of parts, and in Inventor partdocuments are .ipt 😉
What version of Inventor are you using? I used a function available since 2014 which should work..
See spoiler for reference to API page
Spoiler
PartDocument.AppearanceSourceType Property
Parent Object: PartDocument
Description
Gets and sets the source of the appearance for the part. Setting to kMaterialAppearance will clear appearance override so the document uses the appearance associated with the active material.
Syntax
PartDocument.AppearanceSourceType() As AppearanceSourceTypeEnum
Version
Introduced in Inventor version 2014
Inventor 2014 SP2
Message 8 of 19
I am using Inventor Professional 2016
Message 9 of 19
Jef_E
I checked it for me, and it works on Inventor 2014. I don't know if there is a change in the appearance API since 2014?
Maybe someone else can fill that in, but for me this is the best working solution I can give as it works seamless at my end.
Inventor 2014 SP2
Message 10 of 19
Maybe it's the file? Can I send you one of the files so you can try?
Message 11 of 19
Jef_E
Sure, attach a file and I will check.
Inventor 2014 SP2
Message 12 of 19
Hey, sorry for my late response. I thought I replied but the post didn't go through or something.
I've attached a file for you to look at, it's an IPT file because I can't attach IGS files. (I opened the IGS and saved it as IPT)
Thank you
Message 13 of 19
Curtis_Waguespack
Hi stijn_paardekooper,
I only skimmed though this discussion, but here is an example that I use. I run it from an assembly and it strips the overrides for each part, and for the assembly file. I've used this in Inventor 2015, but I don't recall if I've tested this in Inventor 2016 or 2017 yet.
I hope this helps.
Curtis
Trace.WriteLine("Strip Color OverRides", "iLogic") 'debug
Dim oAssyDoc As AssemblyDocument
oAssyDoc = ThisApplication.ActiveDocument
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = oAssyDoc.ComponentDefinition
Dim oOcc As ComponentOccurrence
'strip color overrides at the assembly level
For Each oOcc In oAssyDoc.ComponentDefinition.AppearanceOverridesObjects
	oOcc.AppearanceSourceType = 100612 'kPartAppearance
Next
'strip color overrides at the part level
For Each oOcc In oAsmCompDef.Occurrences.AllLeafOccurrences
    oDef = oOcc.Definition'.Document
	oDef.Material.UpdateFromGlobal
	oDef.Document.AppearanceSourceType = 100614 'kMaterialAppearance
	'Trace.WriteLine(oOcc.Name, "iLogic") 'debug
	 For Each obj In oDef.AppearanceOverridesObjects
		'strip color overrides at the feature level
		If TypeOf obj Is SurfaceBody Then
            obj.AppearanceSourceType = 100612 'kPartAppearance
			'Trace.WriteLine(obj.Name, "iLogic") 'debug
        ElseIf TypeOf obj Is PartFeature Then
        ElseIf TypeOf obj Is Face Then
			'Trace.WriteLine("Face", "iLogic") 'debug
        Else
    Next
	'Purge Appearances And Materials
	'By Adam Nagy
	'http://adndevblog.typepad.com/manufacturing/2015/10/purge-appearances-and-materials.html
	oDoc = oOcc.Definition.Document
	' There can be references between assets,
	' so keep doing it until only used things remain
	Dim foundUnused As Boolean
	Do
		foundUnused = False
		Dim a As Asset
		For Each a In oDoc.Assets
			If Not a.IsUsed Then
			a.Delete
			foundUnused = True
		Next
	Loop While foundUnused
Next
Message 14 of 19
Hey,
Thanks for you reply. The code doesn't work for me, or at least doesn't do what I want it to do.
Have you tried it with the attached ipt file? Maybe it works for you
Message 15 of 19
Jef_E
Please attach the .igs file by zipping it. Then you can upload it.. I can't open Inventor 2016 files I am only capable to open up to 2014.
Inventor 2014 SP2
Message 16 of 19
Luisfmts
Jesus...how could i think about iLogic when I had a pretty easy solution like this and Styles Editor Purge/Update!? Smiley LOL
Message 17 of 19
Would it be a lot of work for someone familiar with Ilogic, to modify this code so it runs only on "selected" parts (not on ALL)?
https://forums.autodesk.com/t5/inventor-customization/clear-all-appearance-overrides-in-part-with-il...
Message 18 of 19
RoyWickrama_RWEI
Thanks for your posting. It improved my iLogic knowledge.
In my coding, I used the following to restore part color:
But, I now need to assign color (say Steel).
Could you help me to get around this.
look forward to receiving help.
Message 19 of 19
D.Motshagen
@RoyWickrama_RWEIThanks, this was what I was looking for!
To clear the override in a part:
use this code in a part.
It is so simple.
'clear override in a part
'Found at: https://forums.autodesk.com/t5/inventor-ilogic-and-vb-net-forum/clear-all-appearance-overrides-in-part-with-ilogic/m-p/8226065/highlight/true#M88140
 	oDoc = ThisApplication.ActiveDocument
