ReferencedOLEFileDescriptors.Add
If I use the function ReferencedOLEFileDescriptors.Add with the option of embedding a file I get an "Invalid Procedure" call error.
It works fine if I link the file.
Any ideas?
This works:
Dim oDrawDoc As DrawingDocument
Set oDrawDoc = ThisApplication.ActiveDocument
Dim xtt As ReferencedOLEFileDescriptor
Set xtt = oDrawDoc.ReferencedOLEFileDescriptors.Add("1.doc")
Unload Me
This does NOT:
Set xtt = oDrawDoc.ReferencedOLEFileDescriptors.Add("1.doc", kOLEDocumentEmbeddingObject)
Unload Me
The API currently does not support adding embedded OLE references. The only
option is to use linking.
Sanjay-
wrote in message news:[email protected]...
This works:
Unload Me
This does NOT:
Unload Me
That would explain why it is not working....
Thanks!
Crstiano
Hi Sanjay,
"The API currently does not support adding embedded OLE references "
Today (7y ago), this information is valid?
Cristiano Oliveira
ConsultCAD.com
maxstels
Also interesting
