Reference key of point
Hello Everyone,
I am using the select event to select entities on a component, but when I select on a point of an edge, it is not a point type. I would like to get the reference key to that point, how can I do that? Please help me in this case! 🙂
Thank you
WCrihfield
It's most likely a Vertex object, instead of an actual Point object.
Try defining the object you selected as a Vertex, that should allow you to get the ReferenceKey.
Wesley Crihfield
(Not an Autodesk Employee)
WCrihfield
A code like this should work:
Dim oPDoc As PartDocument = ThisApplication.ActiveDocument
Dim oPDef As PartComponentDefinition = oPDoc.ComponentDefinition
Dim oObj As Object = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartVertexFilter, "Select A Vertex.")
If oObj Is Nothing Then
	MsgBox("Selection was canceled. Exiting.", vbOKOnly, " ")
	Return
End If
If oObj.Type.ToString <> "67120432" Then
	MsgBox("Item selected was not a Vertex. Exiting.", vbOKOnly, " ")
	Return
End If
Dim oVertex As Vertex = oObj
Dim oRefKey() As Byte
Dim oKeyContext As Integer = 1
Try
	oVertex.GetReferenceKey(oRefKey)
Catch oEx As Exception
	MsgBox("The GetReferenceKey Sub failed." & vbCrLf & _
	"The Error Message is as follows:" & vbCrLf & _
	oEx.Message & vbCrLf  & vbCrLf & _
	"And the Source was as follows:" & vbCrLf & _
	oEx.Source & vbCrLf & vbCrLf & _
	"And the StackTrace was as follows:" & vbCrLf & _
	oEx.StackTrace, vbOKOnly + vbExclamation, " ")
End Try
Although, in some of my tests, it returned the following error message.
Wesley Crihfield
Yah, thanks for your help. Let me try from my side with your solution.
