Dim oDrawDoc As DrawingDocument
oDrawDoc = ThisApplication.ActiveDocument
' a reference to the active sheet.
Dim oActiveSheet As Sheet
oActiveSheet = oDrawDoc.ActiveSheet
' a reference to the drawing curve segment.
' Please select a linear drwaing curve.
Dim oDrawingCurveSegment1 As DrawingCurveSegment
oDrawingCurveSegment1 = ThisApplication.CommandManager.Pick(kDrawingCurveSegmentFilter, "Select a linear curve")
' a reference to the drawing curve.
Dim oDrawingCurve1 As DrawingCurve
oDrawingCurve1 = oDrawingCurveSegment1.Parent
' Get the mid point of the selected curve
' assuming that the selection curve is linear
Dim oMidPoint1 As Point2d
oMidPoint1 = oDrawingCurve1.MidPoint
Dim oDrawingCurveSegment2 As DrawingCurveSegment
oDrawingCurveSegment2 = ThisApplication.CommandManager.Pick(kDrawingCurveSegmentFilter, "Select a linear curve for the 2nd leader")
Dim oDrawingCurve2 As DrawingCurve
oDrawingCurve2 = oDrawingCurveSegment2.Parent
Dim oMidPoint2 As Point2d
oMidPoint2 = oDrawingCurve2.MidPoint
'a reference To the TransientGeometry Object.
Dim oTG As TransientGeometry
oTG = ThisApplication.TransientGeometry
Dim oLeaderPoints As ObjectCollection
oLeaderPoints = ThisApplication.TransientObjects.CreateObjectCollection
' Create a few leader points.
oLeaderPoints.Add(oTG.CreatePoint2d(oMidPoint1.X + 5, oMidPoint1.Y + 10))
'oLeaderPoints.Add(oTG.CreatePoint2d(oMidPoint1.X + 10, oMidPoint1.Y + 10)) ' use this to add a second point to the leader
' Create an intent and add to the leader points collection.
' This is the geometry that the symbol will attach to.
Dim oGeometryIntent1 As GeometryIntent
oGeometryIntent1 = oActiveSheet.CreateGeometryIntent(oDrawingCurve1)
Dim oGeometryIntent2 As GeometryIntent
oGeometryIntent2 = oActiveSheet.CreateGeometryIntent(oDrawingCurve2)
Call oLeaderPoints.Add(oGeometryIntent1)
Dim oLeaderNote As LeaderNote
oLeaderNote = oActiveSheet.DrawingNotes.LeaderNotes.Add(oLeaderPoints,"Hello World")
oLeaderPoints.Clear
Call oLeaderPoints.Add(oGeometryIntent2)
oLeaderNote.Leader.RootNode.AddLeader(oLeaderPoints)
