Reference dims in assembly file
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello to All,
i am trying to code a rule that will add a couple reference dimensions in an assembly module so that the user can have a reference on the screen to some critical dims in the assembly. this can be done in the assembly module (see attached), but would like to code it . i have done some coding for dims on Drawings, but not for in the assembly module. have searched thru the forms and the API samples, but have not found any examples.
i assume this would be similar to adding a dim in a drawing, but no need for Transient Geometry? do you still need to create center marks and 2D points?
thanks for any help or insight into this!
