Recording keyboard sequences
mjohnson
Message 1 of 43
mjohnson
Is it possible to record keyboard sequences to shorten a repeated series of mouse clicks and keyboard entries that I find I am doing over and over throughout the work day?  I was able to do this with Creo software and was hoping it is available for Inventor.
Accepted solutions (3)
Replies (42)
Message 2 of 43
swalton
I am not aware of anything similar to Creo Mapkeys.
You might be able to write some iLogic rules to automate your tasks, but that requires understanding the iLogic scripting language. I don't find it as easy as recording macros with Mapkeys.
Steve Walton
Inventor 2025
Vault Professional 2025
Message 3 of 43
alewer
Inventor does not generally have a straightforward way to record and replay inputs like mouse clicks and keystrokes. There are however generic (not specifically for Inventor) tools like AutoHotkey that might help. What Inventor does have is a powerful API that can automate almost everything that you can do with the GUI... but with a with a different (and more powerful) approach than simply automating a user's mouse+keyboard inputs. You can use the API with VBA macros, iLogic, .NET add-ins, and .NET standalone applications. Can you provide an example of the sort of task that you are trying to automate?
Resources:
AutoHotkey
Inventor API User's Manual
Inventor iLogic API VBA forum
Message 4 of 43
mjohnson
Thankyou for the feedback.
For each part file I link the sketch parameters for the overall size(x and y dimension) to the iproperties custom dialog box.  This way the drawing part description, which includes the overall size of the part, in the drawing and in the assembly drawing BOM description shows up accurately.  Previously we were manually typing these dimensions into the description but every time the part size changed we would need to remember to change the description to match.
I would like to automate the process of creating and exporting the parameters to the part description.
Where I worked before we used Creo and there was a tool called Mapkeys that would have worked great for this application.
 I will check out the Inventor API User's Manual you linked to below and learn how to automate the Inventor way however I'm not very familiar with VBA macros.   Thanks for the feedback!
Message 5 of 43
swalton
Are you leveraging iProperty Expressions?
https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/CloudHelp/cloudhelp/2016...
Have you considered creating specfic part template files to build common shapes with all the iProp and Parameter modifications already completed?
Steve Walton
Inventor 2025
Message 6 of 43
mjohnson
Unfortunately most of our parts are created from existing parts using "copy design" so we don't normally start from scratch with a part template.
The iProperty expressions link you sent may be helpful though.
Message 7 of 43
swalton
I am seeing some issues with Vault Copy Design and iProperty expressions.  I suspect that I have something miss-configured because Copy Design is wiping out the expression and replacing it with the text from the parent.
I have a post over in the Vault forum trying to see what I need to change to fix the issue.
Steve Walton
Inventor 2025
Message 8 of 43
mjohnson
Thanks, I will keep that in mind going forward.  I appreciate your input.
Message 9 of 43
A.Acheson
Can you supply a quick screenshot or even list of the parameters to iproperties you usually transcribe? If they are the same for each document it should be an easy rule to make. You would use an external rule(independent/external to files) which would look to the document grab the document parameter value and then inject it into the iproperty you want. The sample you provide can be used to help target a rule to suit your task.
Regards
Alan
Message 10 of 43
mjohnson
Below shows shows the steps I would take to create the part description.  d0 is always the longest dimension and d1 always the shortest.  In the parameters dialog box I select "d0", "d1" and "THICKNESS" for export.  Then I go into the iProperties, Custom tab and copy the formula "=<THICKNESS> X <d1> X <d0> LG." into the "size" entry.  I have to do this for every part the appears on a drawing for the description to be correct.
Message 11 of 43
A.Acheson
Thanks for supplying the screen shots and descriptions that really helps to find the correct information.
If you are not familiar with working with external rules here are two links to get you started.
https://autodeskmfg.typepad.com/blog/2012/01/working-with-external-ilogic-rules.html
https://forums.autodesk.com/t5/inventor-forum/add-create-external-rule-ilogic/td-p/6033312
Paste the rule below into the external rule editor and then run on your part document.
'http://inventortrenches.blogspot.com/2013/10/ilogic-how-to-learn-inventors.html
'https://forums.autodesk.com/t5/inventor-forum/add-create-external-rule-ilogic/td-p/6033312
'https://forums.autodesk.com/t5/inventor-forum/ilogic-that-tells-the-difference-between-parts-and-assemblies/td-p/6211252
DocType = ThisApplication.ActiveDocument.DocumentType
If DocType  = DocumentTypeEnum.kAssemblyDocumentObject Then
	MessageBox.Show("it's an assembly file - Exiting!", "iLogic")
Else If DocType = DocumentTypeEnum.kPartDocumentObject Then
	'MessageBox.Show("it's a part file", "iLogic")
'Get the document we want to work with
Dim partDoc As PartDocument
partDoc = ThisApplication.ActiveDocument
Try
'https://modthemachine.typepad.com/my_weblog/2010/04/parameters-as-iproperties.html
'Export parameters as custom iproperty (Tick the box)
Dim param As Parameter
param = partDoc.ComponentDefinition.Parameters.Item("d0")
param.ExposedAsProperty = True
param = partDoc.ComponentDefinition.Parameters.Item("d1")
param = partDoc.ComponentDefinition.Parameters.Item("Thickness")
Catch
MessageBox.Show("One of the parameters is missing", "iLogic")
End Try
' Get the User Defined property set.
Dim UserDefinedPropSet As PropertySet
UserDefinedPropSet  = partDoc.PropertySets.Item("Inventor User Defined Properties")
' Get the Size property.
Dim SizeProp As Property
SizeProp = UserDefinedPropSet.Item("Size")
Try
' Add an expression to the custom property.
SizeProp.Expression = _
                     "=<Thickness> X <d1> X <d0> LG."
Catch
End Try
Else If DocType = DocumentTypeEnum.kDrawingDocumentObject Then
	MessageBox.Show("it's a drawing file - Exiting!", "iLogic")
The rule above contains API expressions that have been found from helpful topics online which are laid out in a user friendly way specific to the topics. This information is also available in the API help although the contents may not be as digestible. This link shows how to find this information,
Here is some deeper learning to show the capabilities
https://knowledge.autodesk.com/support/inventor/learn-explore/caas/CloudHelp/cloudhelp/2022/ENU/Inve...
https://www.autodesk.com/autodesk-university/class/Inventor-iLogic-Beyond-Basics-2017#video
Regards
Alan
Message 12 of 43
cadman777
Here's a thread that may help you figure something out.
I have no experience in it, so just giving you a heads-up for further investigation.
Also you can look up app in the Autodesk Inventor App Store.
Maybe there's something there that can help without having to dive into the morass of coding.
... Chris
Win 7 Pro 64 bit + IV 2010 Suite
ASUS X79 Deluxe
Intel i7 3820 4.4 O/C
64 Gig ADATA RAM
Nvidia Quadro M5000 8 Gig
3d Connexion Space Navigator
Message 13 of 43
mjohnson
Awesome! thankyou.
It seems to be getting hung up on line 37.  See yellow highlight below.
Message 14 of 43
mjohnson
Thank you, I will check it out.
Message 15 of 43
A.Acheson
Use Inventor.Property instead of Property
when declaring the property.
This is a common issue in changing VBA code back to Vb.Net code. I am not sure why it needs this but is one of differences.
Regards
Alan
Message 16 of 43
mjohnson
It worked! thank you for your help.
One more minor issue.  I still have to go into parameters - custom Property Format - and change the format from decimal to fraction as shown below otherwise the drawing description shows these dimension in decimal format.  Looks like the default is set to decimal.
I had to do this before also but forgot to mention it earlier.
Message 17 of 43
A.Acheson
No problem. I left out that formatting so if you look to this article you will see the snippets of code needed to change that formatting. Insert what you need, likely just the precision line needed.
And this post here is specific to changing precision to fraction.
“param.CustomPropertyFormat.Precision=Inventor.CustomPropertyPrecisionEnum.kSixteenthsFractionalLengthPrecision“
You can set this rule to run on all parts in an assembly if you want (extra speed) a little more work but more time with your feet up later. Here is the link.
Regards
Alan
Message 18 of 43
mjohnson
Thank you for sending the links.
I was not able to get any of these to work in my case.  I don't know enough about coding to figure out what is wrong.
I just need "Thickness", "d0" and "d1" to change from decimal to Fractional, and precision to be 1/16".
Is there a code I could insert into the snippet you already sent me?
I appreciate all of your help.
Message 19 of 43
A.Acheson
Please make sure you copy the same settings under each parameter value. I have corrected the rule below. See if that works. If it does not please post the rule you are running and hopefully we can find the issue.
Try
'[d0
param = partDoc.ComponentDefinition.Parameters.Item("d0") param.ExposedAsProperty = True oFormat=param.CustomPropertyFormat
oFormat.PropertyType = Inventor.CustomPropertyTypeEnum.kTextPropertyType oFormat.Units="in"
 oFormat.ShowUnitsString = True
oFormat.Precision = Inventor.CustomPropertyPrecisionEnum.kSixteenthsFractionalLengthPrecision
'oFormat.ShowTrailingZeros = False
'oFormat.ShowLeadingZeros = False ']
'[ d1 param = partDoc.ComponentDefinition.Parameters.Item("d1") param.ExposedAsProperty = True oFormat=param.CustomPropertyFormat
'[Thickness param = partDoc.ComponentDefinition.Parameters.Item("Thickness") param.ExposedAsProperty = True oFormat=param.CustomPropertyFormat
'oFormat.ShowLeadingZeros = False '] Catch MessageBox.Show("One of the parameters is missing", "iLogic") End Try ' Get the User Defined property set. Dim UserDefinedPropSet As PropertySet UserDefinedPropSet = partDoc.PropertySets.Item("Inventor User Defined Properties") ' Get the Size property. Dim SizeProp As Inventor.Property SizeProp = UserDefinedPropSet.Item("Size") Try ' Add an expression to the custom property. SizeProp.Expression = _ "=<Thickness> X <d1> X <d0> LG." Catch MessageBox.Show("One of the parameters is missing", "iLogic") End Try Else If DocType = DocumentTypeEnum.kDrawingDocumentObject Then MessageBox.Show("it's a drawing file - Exiting!", "iLogic") End If
 Here is a post that goes through these settings. Just in case they were not set correctly
https://forums.autodesk.com/t5/inventor-ilogic-api-vba-forum/change-format-of-exported-parameter-to-...
Edit: Corrected formatting errors above.
Regards
Alan
Message 20 of 43
A.Acheson
After testing the previous rule, I noticed that if the "size" iProperty is missing and the rule will error out. Here is the corrected version which adds the iProperty before attempting to assign the expression.
ElseIf DocType = DocumentTypeEnum.kPartDocumentObject Then
	Try
	Dim param As Inventor.Parameter
	Dim oFormat As CustomPropertyFormat
	'[d0
	oFormat = param.CustomPropertyFormat
	oFormat.Units = "in"
	oFormat.Precision = Inventor.CustomPropertyPrecisionEnum.kSixteenthsFractionalLengthPrecision'oFormat.ShowTrailingZeros = False
	'[d1
	'[Thickness
	Catch
	End Try
	Try
	Catch
	' Failed to get the property, which means it doesn't exist so we'll create it.
	UserDefinedPropSet.Add("", "Size")
	End Try
	'Add an expression to custom property
	MessageBox.Show("Size: " & SizeProp.Value, "iLogic- Success iProp Updated")
ElseIf DocType = DocumentTypeEnum.kDrawingDocumentObject Then
And here is another version using VB.Net method instead of a pure iLogic rule. I have just place the parameter export into a sub routine as they have all the same formatting it makes the rule a little easier to read.
Sub Main
'Get the document we want to work with Dim partDoc As PartDocument partDoc = ThisApplication.ActiveDocument Try 'Pass document and parameter to sub routine ParameterExport(partDoc, "d0") ParameterExport(partDoc, "d1") ParameterExport(partDoc, "Thickness") Catch MessageBox.Show("One of the parameters is missing", "iLogic") End Try ' Get the User Defined property set. Dim UserDefinedPropSet As PropertySet UserDefinedPropSet = partDoc.PropertySets.Item("Inventor User Defined Properties") ' Get the Size property. Dim SizeProp As Inventor.Property Try SizeProp = UserDefinedPropSet.Item("Size") Catch ' Failed to get the property, which means it doesn't exist so we'll create it. UserDefinedPropSet.Add("", "Size") SizeProp = UserDefinedPropSet.Item("Size") End Try 'Add an expression to custom property SizeProp.Expression = _ "=<Thickness> X <d1> X <d0> LG." MessageBox.Show("Size: " & SizeProp.Value, "iLogic- Success iProp Updated") ElseIf DocType = DocumentTypeEnum.kDrawingDocumentObject Then MessageBox.Show("it's a drawing file - Exiting!", "iLogic") End If End Sub Sub ParameterExport(oPartDoc As Document, oParam As String) 'Export parameters as custom iproperty (Tick the box) Dim param As Inventor.Parameter Dim oFormat As CustomPropertyFormat param = oPartDoc.ComponentDefinition.Parameters.Item(oParam) param.ExposedAsProperty = True 'Carry out formatting oFormat = param.CustomPropertyFormat oFormat.PropertyType = Inventor.CustomPropertyTypeEnum.kTextPropertyType oFormat.Units = "in" oFormat.ShowUnitsString = True oFormat.Precision = Inventor.CustomPropertyPrecisionEnum.kSixteenthsFractionalLengthPrecision End Sub
Regards
Alan
