'Rebuild All' through all subassemblies to correct branches (Tube and Pipe)
Hi All,
(Inventor Professional 2017.4.2)
I'm having a persistent problem with tube and pipe branch fittings not updating when equipment is moved in the top level assembly. Runs/Routes adapt but the branch fittings attached to them remain in position. This is occurring for a variety of branch types from ones I have authored to CC standard sockolets etc... They can be prompted to move by opening the offending run and clicking 'rebuild all' but this has to be done in each run subassembly. The same result can be obtained by setting the connection of the branch fitting to user defined '0' but this takes longer as each connection has to be adjusted.
Needless to say this is annoying and not very parametric behavior!
Adrian Salariu covered this type of issue in this idea station:
What I'm interested in (unless the problem is about to be resolved by Autodesk) is an Ilogic method of rebuilding all runs from the top level tube and pipe assembly so each run does not have to be individually updated. The standard rebuild all command does not seem to penetrate these sub-assemblies.
Thanks in advance...
Glenn
