Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Reading "Prompted Entry" Title Block info with VBA
I've spent ages reading similar-ish posts, and made up some code to read the values from the title block on an idw.
Does it make any difference if the 'type' of the property feild is 'Prompted Entry' (I don't think it should)
I just want my VBA prog to read all the values in the titleblock. Here is the code to try and read one value, and then display it in a massage box:
Dim oPropsets As PropertySets
Set oPropsets = ThisApplication.ActiveDocument.PropertySets
Dim oBlock As PropertySet
Set oBlock = oPropsets("{D5CDD505-2E9C-101B-9397-08002B2CF9AE}")
Dim oBlockProp As Property
For Each oBlockProp In oBlock
Select Case oBlockProp.Name
Case "COMPANY"
MsgBox oBlockProp.Value
End Select
Next
Thanks for any help
I have been experimenting with all the ways I think people
have been doing this, and I can't get anything to work.
I would like to know if this is actually possible, or
am I just wasting time.
If there is an old drawing, with 'prompted entry' info
in the title block, can I run a macro that will read that
titleblock information and display it in a textbox?
If so how?
I would be very grateful if someone could help me with this
Joe
The value of a prompted entry is in the FormatedText property of the
titleblocks TextBox. I use the following function to retrieve the value for
a specified promted text.
Public Function IvGetPromptedValue(ByRef oTbl As Inventor.TitleBlock, _
sPromptName As String) As String
'get value of specified prompted property from titleblock and return it
'with Function. If property can't be found return "-1"
'references:
'mXML.ParseXML
Dim oTextBoxes As Inventor.TextBoxes
Dim lBox As Long
'get textboxes of titleblock
Set oTextBoxes = oTbl.Definition.Sketch.TextBoxes
'iterate through text boxes and find value
For lBox = oTextBoxes.Count To 1 Step -1
If Left(GetFormattedText(oTextBoxes(lBox)), 8) = "" Then
Dim sValue As String
sValue = ParseXML(oTextBoxes(lBox).FormattedText, "Prompt")
If UCase(sValue) = UCase(sPromptName) Then
IvGetPromptedValue = oTbl.GetResultText(oTextBoxes(lBox))
Exit Function
End If
End If
Next
IvGetPromptedValue = "-1"
End Function
Private Function GetFormattedText(ByRef oTextBox As Inventor.TextBox) As
String
'get value of formatted text property. If error return error string
On Error Resume Next
GetFormattedText = oTextBox.FormattedText
If Err Then
Err.Clear
GetFormattedText = ""
End If
End Function
-Frank
Thanks very much for the help, but as I'm a bit new to VBA
I am very frustrated with myself as I cannot understand
everything in the code.
I'm used to using subs, and am a bit unsure about functions.
I'm not sure what the 'ByRef oTbl As Inventor.titleblock'
is refering to in the arguments for the first function.
And is the 'ParseXML' important, as I can't find any
reference to it in my VBA help. How do the two functions
relate to each other, ie which on do I call.
And Im having trouble calling the functions, I'm not sure
what to put in the argument list.
(I'm worried I put the wrong thing in my original question,
I want to read the values from the titleblock, and just
use them elsewhere. As long as I can get a set of text
strings containing the values in the title block, i'll be
happy)
Thanks for the previous help
- You can use a function the same way that you use
a sub.  In this case a function is used because it can return a value
to the calling statement.
- ByRef passes the address of the argument
instead of the value, which lets you change the variables actual
value.
- oTbl As Inventor.Titleblock is the titleblock
object which represents an instance of a title block on a sheet.
face=Arial size=2>
- ParseXML is a function that I've got from
somebody on the net, that returns the value of an XML string.
The following code returns the value for a prompted
property of a title block on the first sheet of a drawing document.  Let me
know if you need more information on how to extract the file property values of
the title block.
Frank
'start
code========================================================================
Option Explicit
Const xs = "<"
Const xe = ">"
Const
xend = "</"
Sub test()
    Dim oDoc As
DrawingDocument
    Dim oTbl As
TitleBlock
    Set oDoc =
    Set oTbl =
oDoc.Sheets(1).TitleBlock
    'Name of
prompted property that you extract the value for
    Dim sPropName As String
    sPropName
= "<replace this with your property name>"
    Dim sPropValue As String
    sPropValue
= IvGetPromptedValue(oTbl, sPropName)
    MsgBox "Prompted Property" & vbCrLf & vbCrLf
& sPropName & " = " & sPropValue, vbOKOnly
End Sub
_
return "-1"
'references:
'mXML.ParseXML
    Dim oTextBoxes As
Inventor.TextBoxes
    Dim lBox As Long
    Set
value
-1
        If
Left(GetFormattedText(oTextBoxes(lBox)), 8) = "<Prompt>"
Then
            Dim
sValue As
String
"Prompt")
            If
Then
Exit
Function
End If
        End
If
    Next
End Function
String
string
    GetFormattedText =
    If Err
Then
Err.Clear
        GetFormattedText =
"<Application-defined or object-defined error>"
    End
If
End Function
Private Function ParseXML(ByVal XMLSource As String,
_
    ByVal XMLName As String, _
Optional Instance As Integer = 1, _
    Optional Default As
Variant = "") As String
    Dim x As Integer, y As Integer, XMLStart As Integer,
XMLTag As String, c As String
    Dim XMLTagEnd As
String
    Dim XMLMatch As Integer, XMLEnd As Integer,
XMLLength As Integer
    XMLLength =
Len(XMLSource)
    XMLTag = xs + XMLName +
xe
    XMLTagEnd = xend + XMLName + xe
    '*** Find the start of the requested
intstance...
    XMLStart = 1
    For x = 1
To Instance
        y = InStr(XMLStart,
XMLSource, XMLTag)
        If y >=
XMLStart
Then
XMLStart = y + Len(XMLTag)
Else
ParseXML =
Default
Exit Function
        End
If
    Next
Find the end of the instance...
    XMLEnd =
XMLStart
    XMLMatch = 1
    Do Until
XMLMatch = 0
        c = Mid(XMLSource,
XMLEnd, Len(XMLTagEnd))
        If c =
XMLTagEnd
Then
XMLMatch = XMLMatch - 1
        ElseIf
Left(c, 1) = xs
Then
XMLMatch = XMLMatch + 1
        End
If
        XMLEnd = XMLEnd +
1
        If XMLEnd = XMLLength
Then
ParseXML =
Default
Exit Function
        End
If
    Loop
ParseXML = Mid(XMLSource, XMLStart, XMLEnd - XMLStart - 1)
End Function
'end
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
happy)
Thanks for all the help. I have finally managed to get the titleblock info!
I used the suggest code from Lian Xie (thank you!) to get the values I wanted. I suppose it will be useful if I post my successful solution, just in case anyone else is interested:
Public Sub TitleBlock()
Dim oDoc As DrawingDocument
Set oDoc = ThisApplication.ActiveDocument
Dim oTitle As Inventor.TitleBlock
Set oTitle = oDoc.ActiveSheet.TitleBlock
Dim oTextBox As TextBox
Dim oTextBoxes As TextBoxes
Dim sData As String
Set oTextBoxes = oTitle.Definition.Sketch.TextBoxes
For Each oTextBox In oTextBoxes
sData = oTitle.GetResultText(oTextBox)
If oTextBox.text = "COMPANY" Then
Company = sData
ElseIf oTextBox.text = "SALES ORDER No" Then
SalesOrderNo = sData
ElseIf oTextBox.text = "TITLE LINE 1" Then
TitleOne = sData
ElseIf oTextBox.text = "TITLE LINE 2" Then
TitleTwo = sData
ElseIf oTextBox.text = "DRAWING NUMBER" Then
DrgNoOne = sData
ElseIf oTextBox.text = "DRAWING NUMBER 2 " Then
DrgNoTwo = sData
ElseIf oTextBox.text = "DRAWN BY" Then
Author = sData
End If
Next
End Sub
Thats it!
(Note: if anyone who understands this is reading, I can't post this using the via newsgroup, using outlook newsreader. For some reason it wont accept my username and password for the discussion.autodesk.com server. This username and password work fine for the web based version...?)
Again, Thanks All
Joe
There was just a similar discussion in the Inventor 6 Newsgroup.
Have you tried just going here
http://discussion.autodesk.com/[email protected]@.ee93814
and clicking on the group under the Newsreader column? If you are able to read but not
post it may be some sort of firewall issue at your company?
Kent
Assistant Moderator
Autodesk Discussion Forum Moderator Program
"joeabberley" wrote in message news:[email protected]...
the web based version...?) Again, Thanks All Joe
