Reading each columns of BomRow with VB.NET?
mucip
Message 1 of 11
mucip
I have assembly file and try to reading BomTable with structured ad first level options.
By the way I want to use custom BomTableFormat with below code:
oBOM.ImportBOMCustomization("C:\EXAMPLE\StansardIAM.xml")
I can read BomRow but I can not get the cell (column) of the each row. Because I need the information cell by cell from custom BOM format.
My Code is:
 Dim activeDoc As Document = inv_App.ActiveDocument
        ' Cast the active document as an assembly document
        Dim assemblyDoc As AssemblyDocument = DirectCast(activeDoc, AssemblyDocument)
        ' Get the Bill of Materials
        Dim bom As BOM = assemblyDoc.ComponentDefinition.BOM
        'İhtiyaç duyulan bilgiler eklenmiş hali...
        bom.ImportBOMCustomization(baslangicKlasor & "\StructuredBOM.xml")
        bom.StructuredViewFirstLevelOnly = True
        ' Make sure that the structured view is enabled.
        bom.StructuredViewEnabled = True
        Dim bomView As BOMView = bom.BOMViews.Item("Structured")
        If bomView Is Nothing Then
            MessageBox.Show("The 'Structured' BOM view is not available.", "Error")
            'hataliGiris = True
            Exit Sub
        'Tabloyu okuyor.
        For Each row As BOMRow In bomView.BOMRows
            Console.WriteLine(row.ItemNumber & " --- " & row.ItemQuantity)
        Next
By the way I want to read BomTable from IAM file not IDW.
Mucip:)
Replies (10)
Message 2 of 11
marcin_otręba
you can read xml to get columns directly from it, the same you can create invisible drawing and place partlist and read columns.
Hi, maybe you want to check my apps:
DrawingTools   View&ColoringTools   MRUFolders
Message 3 of 11
mucip
Yes I can Export BOM List to csv file and parse it. But It must be easier way I guess? Because I can reach bom list already and I should reach to each cell of the row.
Mucip:)
Message 4 of 11
marcin_otręba
nope, there is no way to access columns in bom directly.
Message 5 of 11
Michael.Navara
Hi @mucip
As @marcin_otręba mentioned above, it is not possible to access BomRow cells. But BomRow provides some information such as quantity, item number, etc. Rest of information you need to extract from associated ComponentDefinitions of the BomRow.
Message 6 of 11
mucip
Well, I need to parse bom output csv file than.🤔
Thanks...
Mucip:)
Message 7 of 11
mslosar
You can also access the parts/assemblies from the BOMRow as well and pull the data from their parameters/iproperties.
Message 8 of 11
mucip
Can you give any sample code or website please?
Mucip:)
Message 9 of 11
mucip
By the way when I use Structured BOM and try to read BomRow I can see only the main branch.
How can I open all rows and read them?
Mucip:)
Message 10 of 11
marcin_otręba
use .childrows, for complete code see this:
Solved: How to read item number as per structured view - Autodesk Community
Message 11 of 11
mucip
I export the structured list as csv file. I don't know why, Exported csv file has full list. Then I read this csv file row by row very easily.
It's very strange behaviour. It looks only first branch but it exports all branch?
Anyway, I solved  by using csv file now.
Mucip:)
