Read the instance property in the occurrences of a drawing
kv5053545
kv5053545
I do not know if you can help me I have an assembly with many occurrences when I want to dimension them in an automatic way it has been complicating me a lot, I just found out that there are the instance property I do not know if it is possible to read them from the code so that if it finds a certain letter in the instance property inside the occurrence it makes the dimensions.
Dim drawingDoc As DrawingDocument = ThisApplication.ActiveDocument
' Loop through each sheet in the drawing document
For Each sheet As Sheet In drawingDoc.Sheets
    ' Loop through each view on the sheet
    For Each view As DrawingView In Sheet.DrawingViews
        If View.Name = "VIEW1" Then
            ' Check if the view is an assembly view
            ' Get the assembly document for the view
            Dim asmDoc As AssemblyDocument = View.ReferencedDocumentDescriptor.ReferencedDocument
            ' Loop through each assembly component
 For Each comp As ComponentOccurrence In asmDoc.ComponentDefinition.Occurrences
                Dim componentName As String = comp.Name
                Dim Search As String = "Wall"
                If componentName.Contains(Search) Then
 ' Add a dimension to the component if the component name contains "Wall"
Dim ShGeneral = ThisDrawing.Sheets.ItemByName("General:1")
Dim genDims = ShGeneral.DrawingDimensions.GeneralDimensions
Dim view1 = ShGeneral.DrawingViews.ItemByName("VIEW1")
 Dim wPl_Wall_FlangeLeft  = view1.GetIntent(comp.Name, "WPl_Wall-FlangeLeft")
 Dim wPl_Wall_FlangeRight = view1.GetIntent(comp.Name, "WPl_Wall-FlangeRight")
  Dim dimX As Double
 Dim dimY As Double
           '' Add the dimension to the drawing
  Dim linDim1 = genDims.AddLinear("Width_" & componente, view1.SheetPoint(dimX, dimY), wPl_Wall_FlangeLeft, wPl_Wall_FlangeRight)
                        End If
            Next
        End If
    Next
Next
dalton98
Yes this is doable. Instance properties are unique for the assembly they are in. They are separate from the typical property sets in an inventor file.
https://modthemachine.typepad.com/my_weblog/2010/02/accessing-iproperties.html
Here is an example of how to access them:
Dim oADoc As AssemblyDocument = ThisDoc.Document
For Each comp As ComponentOccurrence In oADoc.ComponentDefinition.Occurrences
	'check if instance property exists
	If comp.OccurrencePropertySetsEnabled = True
		Dim instanceSearch As String = "test"
		For i = 1 To comp.OccurrencePropertySets(1).Count
'			If comp.OccurrencePropertySets(1)(i).Name.Contains("test")
				MessageBox.Show(comp.OccurrencePropertySets(1)(i).Name, comp.OccurrencePropertySets(1)(i).Value)
'			End If
		Next
	End If
Next
kv5053545
Hi, @dalton98  I have seen how to access to the instance property of the occurrences of an assembly but when I try to do the same inside the occurrences that are inside a view in a drawing, I get this error: iProperties: The component named "Wall_A:1" was not found.
                Dim componente As String = comp.Name
                Dim searchWalls As String = "Wall"
                If componente.Contains(searchWalls) Then
                    Dim wPl_Wall_FlangeLeft  = view1.GetIntent(componente, "WPl_Wall-FlangeLeft")
                    Dim wPl_Wall_FlangeRight = view1.GetIntent(componente, "WPl_Wall-FlangeRight")
					Dim side = iProperties.InstanceValue(componente, "Side")
                    Dim dimX As Double = 0
                    Dim dimY As Double = 0
If side = A Then
	   Dim linDim1 = genDims.AddLinear("SideA" & componente, view1.SheetPoint(dimX, dimY), wPl_Wall_FlangeLeft, wPl_Wall_FlangeRight)
Else If side = B
	   Dim linDim1 = genDims.AddLinear("SideB" & componente, view1.SheetPoint(dimX, dimY), wPl_Wall_FlangeLeft, wPl_Wall_FlangeRight)
ElseIf side = C
	   Dim linDim1 = genDims.AddLinear("SideC" & componente, view1.SheetPoint(dimX, dimY), wPl_Wall_FlangeLeft, wPl_Wall_FlangeRight)
Else If side = D
   Dim linDim1 = genDims.AddLinear("SideD" & componente, view1.SheetPoint(dimX, dimY), wPl_Wall_FlangeLeft, wPl_Wall_FlangeRight)
End If
                End If
            Next
        End If
    Next
Next
A.Acheson
Hi @kv5053545
Try using the occurrence name to target the correct document
Dim side = iProperties.InstanceValue(componente.Name, "Side")
If that doesn't work then you can try the longer API method that Dalton referred too.
	If componente.OccurrencePropertySetsEnabled = True
		Dim instanceSearch As String = "Side"
		For i = 1 To componente.OccurrencePropertySets(1).Count
			If componente.OccurrencePropertySets(1)(i).Name.Contains(instanceSearch)
				MessageBox.Show(componente.OccurrencePropertySets(1)(i).Name, componente.OccurrencePropertySets(1)(i).Value)
			End If
		Next
	End If
Regards
Alan
kv5053545
Hi  @A.Acheson @dalton98 ,  Thank you very much, I was able to implement it in my code and it worked very well.
Do you know if it is now possible to create instance property from vb.net to inventor?
dalton98
edit* do it this way
Dim comp As ComponentOccurrence = oADoc.ComponentDefinition.Occurrences(1)
iProperties.InstanceValue(comp.Name, "test") = "hello"
@kv5053545 You would add instance values the same way as you find them
Enable property sets for the occurrence > add instance property in the first property set
Dim instProp As Inventor.Property = comp.OccurrencePropertySets(1).Add(12, "name")
