Read Iprops from selected occurence in browser
Hi to all,
is there a way to read the iprops from the selected occurrence in the browser pane (assembly and drawing)?
Would like to:
1. manually select occurrence in the browser
2. start macro with keyboard shortcut
3. read iprops of selected occurrence
4. copy iprop to clipboard
Would love some help - if anyone has such a code available - would greatly appreciate a copy?
Alex
Ralf_Krieg
In an assembly, you should first check if your Document.SelectSet contains a ComponentOccurrence (and not e.g. a Workplane). If so you can traverse through ComponentOccurrence.Definition.Document.PropertySets to the Property you want.
In a drawing a selected browsernode returns only a generic object. The only way I can think of, is to recursive traverse through DrawingDocument.BrowserPanes.ActivePane.TopNode.BrowserNodes and search for the node with Selected=True propertie. This node has a NativeObject property containing the ComponentOccurrence. If you got it, you can go on with the assembly method above.
R. Krieg
RKW Solutions
www.rkw-solutions.com
