Read/Control 3Dmodel's annotations 'Active Standard' value (Modelling/Document Settings)
Maxim-CADman77
Advisor Advisor
Maxim-CADman77
I'd like to know whether it possible to control/change (or at least read) value of model's Annotations 'Active Standard' using API?
Please vote for Inventor-Idea Text Search within Option Names
Michael.Navara
You can use undocumented read/write string property ActiveAnnotationsStandard
'Read
Dim activeStandard = ThisDoc.Document.ActiveAnnotationsStandard
Logger.Debug(activeStandard)
'Write
ThisDoc.Document.ActiveAnnotationsStandard = "ASME"
Maxim-CADman77
But how do you know there is an undocumented property ActiveAnnotationsStandard ?
Michael.Navara
Maxim-CADman77
My fail - as not a VBA-man I constantly forget about this valuable source of undocumented info.
Have found your relevant post.
Double thanks!
WCrihfield
Just dropping the cross-reference link in here to another older forum topic which came to the same results as this one.
https://forums.autodesk.com/t5/inventor-programming-ilogic/how-to-set-activeannotationsstandard/m-p/...
Wesley Crihfield
(Not an Autodesk Employee)
