Re: PRINT ORIENTATION IN ILOGIC
anthony_hendrick
anthony_hendrick
This same printing orientation problem seems to persist some 7/8 on. I too have to print a set of sheets both in landscape and portrait, however there is no option to do both at the same.
I am very intrigued by this macro solution but am having a hard time finding out how to use these files which have been uploaded by mrattray.
Any help would be greatly appreciated.
Anthony
mrattray
What a blast from the past. 8 years later I'm still using the same solution to the same problem, too.
In inventor, from the ribbon, go to tools > VBA editor. Go to file > import and select the files I provided. This will add my files to your current VBA project file. From there you can fire the code a couple different ways. You can add an icon for the macro directly to the ribbon, or what i did is create an iLogic rule that calls it so I could implement it on an iLogic form with several other useful functions.
You then forget that ctrl+p exists and instead use your new print button for all your printing needs.
Mike (not Matt) Rattray
In iLogic, you can set orientation like this.
'Set Rotation Behaviour
oDrgPrintMgr.Rotate90Degrees = False
'oDrgPrintMgr.Rotate90Degrees = True
 I wrote an article about the print options in iLogic that you can access here: https://clintbrown.co.uk/2019/11/30/ilogic-print/
