"Constraint.IsActiveInComponent" gives error
tom89Y38
tom89Y38
Hi all,
I want to suppress a constraint in a sub-assembly. The code that I use:
Constraint.IsActiveInDoc("000090-0000-A.iam", "Insert_180:1")=False
This works perfect but i can't copy and rename the parts because the iLogic rule won't find the filename anymore.
Instead of this i used the following code(like advised on https://knowledge.autodesk.com/support/inventor/learn-explore/caas/CloudHelp/cloudhelp/2020/ENU/Inve... :
Constraint.IsActiveInComponent("Empty_Pallet_Stopper:1", "Insert_180:1") = False
This should work perfect, but it doesn't. I get the following error (see attached image) 
Anyone who could give me some advice? I use Inventor 2019
JhoelForshav
Hi @tom89Y38
It seems that "Insert_180:1" doesn't exist in the component "Empty_Pallet_Stopper:1"?
tom89Y38
It does exist, when i use the filename instead of the display name it works perfect.
JhoelForshav
@tom89Y38
Constraint.IsActiveInComponent seems to take the actual leaf occurrence that the constraint is acting on.
I think this will work for you:
Constraint.IsActiveInComponent("000090-PL0007:1", "Insert_180:1") = False
tom89Y38
This works! thanks a lot!
Looks like i was confused by this explenation on the Autodesk help page:
To copy and rename all the files in an assembly while keeping all the rules intact, use Constraint.IsActiveInComponent and specify a subassembly name instead of the filename.
