"Rebuild all" feature is not active when I connect to inventor with remote inventor api using c#
hayattangercekler2
hayattangercekler2
This time I added the inventor feature (rebuild all) that I was trying to run with the Inventor api directly to the rule in the iam file. Here, I added the trigger function under "close documents" to indicate that the trigger should be done while the file is closing. After sending a request via C# using the Visual Studio IDE and closing the file, the commands on the Ilogic side did not work. Then when I tried it manually again, it works successfully. Even when my file is still open, the "rebuild all" feature does not work when I connect with C# via the inventor api. What is the reason of this ? Do these features turn off when there is a remote access?
My ILogic code:
InventorVb.DocumentUpdate()
ThisDoc.Document.Rebuild2(True)
ThisDoc.Document.Save2(True)
CattabianiI
yes.
In the image you posted there is no document closure. (Application.Quit is different from Document.Close)
