"For" loop throwing exception VB.net
chrisw01a
Message 1 of 10
chrisw01a
Would anyone mind sending me in the correct direction here? Attempting to make a sub to check for Ole files. The commented lines at the bottom work just fine but trying to use a For statement to simplify (lines at the top). On line 4, if the OLEFileDescriptors.Count > 0, I am getting an exception. I suspect it has something to do with the "oleFile" type but I'm lost.
Thank you!
Private Sub checkOle(doc As Inventor.ApprenticeServerDocument)
        'Check for 3rd party references
        Debug.Print(doc.DisplayName & ": " & doc.ReferencedOLEFileDescriptors.Count)
        For Each oleFile As Inventor.ApprenticeServerDocument In doc.ReferencedOLEFileDescriptors
            If Not oleFile Is Nothing Then
                'Handle embedded objects (They don't copy very well)
                If Not oleFile.StartsWith("Embedding") Then
                    'Add the file to the listbox
                    listboxFileView.Items.Add(oleFile)
        Next
'The code below is what I have been using and it works fine but trying to simplify...
        'Dim oleCount As Integer = doc.ReferencedOLEFileDescriptors.Count
        'If oleCount > 0 Then
        '    Dim z As Integer = 0
        '    For z = 1 To oleCount
        '        Dim tpDoc As String = doc.ReferencedOLEFileDescriptors.Item(z).FullFileName
        '        'Added 8-1-11 to handle corrupt? files that had embedded spread sheets
        '        If Not tpDoc = Nothing Then
        '            'Handle embedded objects (They don't copy very well)
        '            If Not tpDoc.StartsWith("Embedding") Then
        '                'Add the file to the listbox
        '                listboxFileView.Items.Add(tpDoc)
        '            End If
        '        End If
        '    Next
        'End If
    End Sub
Replies (9)
Message 2 of 10
Frederick_Law
0 means no OLE Files.
Your old code has:
 Use it before the for loop.
Message 3 of 10
chrisw01a
Same result. It actually passes it when the count = 0. It is when one exists that it throws the exception.
Message 4 of 10
WCrihfield
You are missing a step in this line:
If oleFile represents a ReferencedOLEFileDescriptor object, then that does not have a property called StartsWith.  StartsWith is a method of a String.  I assume you wanted to check the FullFileName or Displayname, or something like that, but that step is missing.
Wesley Crihfield
(Not an Autodesk Employee)
Message 5 of 10
Frederick_Law
What exception did you get?
My next guess is:
doc.ReferencedOLEDescriptors is not compatible with Inventor.ApprenticeServerDocument
Message 6 of 10
WCrihfield
Good catch.  I didn't even notice that we were dealing with an ApprenticeServerDocument here.  My earlier response was way off. 🙄  That object does appear to have the ApprenticeServerDocument.ReferencedOLEFileDescriptors property.  But I just assumed that the items within the ReferencedOLEFileDescriptors would be ReferencedOLEFileDescriptor type objects, not ApprenticeServerDocument objects.
Wesley Crihfield
Message 7 of 10
Frederick_Law
Will this work?
For Each oleFile In doc.ReferencedOLEFileDescriptors
 You still need to get to oleFile.Filename before you can use StartsWith.
Message 8 of 10
chrisw01a
No, that didn't work because now "oleFile" is not defined.
Message 9 of 10
Frederick_Law
I'm guessing ReferencedOLEFileDescriptor is under Inventor:
For Each oleFile As Inventor.ReferencedOLEFileDescriptor In doc.ReferencedOLEFileDescriptors
Message 10 of 10
chrisw01a
Yes, that works! Thanks for taking the time.
