Problems with iLogic BendNote text
damjan_baraga
damjan_baraga
I made rule from different iLogic rules.
It automatically puts note text on the bend line and then changes text to my language with proper height of letters.
Dim oDoc As DrawingDocument = ThisApplication.ActiveDocument
Dim oSheet As Sheet = oDoc.ActiveSheet
Dim oView As DrawingView
Dim oCurve As DrawingCurve
Dim oBendNote As BendNote
For Each oSheet In oDoc.Sheets
    oSheet.Activate()
    For Each oNote As BendNote In oSheet.DrawingNotes.BendNotes
        oNote.Delete()
    Next
Next
sFSize1 = InputBox("Vnesi višino pisave v cm", "Višina pisave", "1")
For Each oView In oSheet.DrawingViews
    For Each oCurve In oView.DrawingCurves
        If (oCurve.EdgeType = Inventor.DrawingEdgeTypeEnum.kBendDownEdge _
                Or oCurve.EdgeType = Inventor.DrawingEdgeTypeEnum.kBendUpEdge) Then
            ' Create the bend note
            oBendNote = oSheet.DrawingNotes.BendNotes.Add(oCurve)
            If oBendNote.Text.Contains("DOWN") Then
			  Dim oText = Replace(oBendNote.Text, "DOWN", "DOL")
                oBendNote.HideValue = True
                oBendNote.Text = oText
           If oBendNote.Text.Contains("UP") Then
               Dim oText = Replace(oBendNote.Text, "UP","GOR")
		oBendNote.FormattedText = "<StyleOverride FontSize='" & sFSize1 & "'>" & oBendNote.Text & "</StyleOverride>"
    Next 'oCurve
Next 'oView
But by changing text I get leathers IQ before text. I don't see where the problem is.
The rule works, if this line is put in comment, but then I can adjust the height of the letters.
A.Acheson
Hi @damjan_baraga
I suggest you make an edit to the bend line text manually then use a loop of bend notes to detect your edited text and then retrieve formatted text to input box. There must be an error in how your implementing the font size overide. Alternatively select another text style with a different size and use that.
Regards
Alan
damjan_baraga
Actually, the real letters are \Q. This is the first key on the keyboard.Is there anybody who already get the same problem?
JelteDeJong
I just wonder why you want to change the text size. It would make more sense if you updated your text style for bend notes.
Jelte de Jong
Blog: hjalte.nl - github.com
