Quick question.
Quick question.
BVasquez78MGR
Quick question.
BVasquez78MGR
Is there a way to incorporate aliases in the Ilogic or VBA Code?
WCrihfield
I am not sure I understand the question, so here is a link about command aliases and shortcuts.  I think if you wanted to launch a command, using that command's keyboard shortcut, from an iLogic rule, you might have to do it with something like System.Windows.Forms.SendKeys.SendWait(), so it would be similar work to just executing the command directly.
Wesley Crihfield
(Not an Autodesk Employee)
BVasquez78MGR
My question is, can I call upon as an alias on code? How would I do that?
