Query regarding changing menu item icon in add-in
I am working on Inventor plug-in which imports my sketching data to the Inventor.
The plug-in itself loads the menu item icon as ".ico" file.
Now I want to change that menu item icon. How it could be possible?
Please reply me soon, if any one knows the solution to the problem.
Thanks in advance!
adam.nagy
Autodesk Support
Autodesk Support
I'm not sure I dunestand what the problem is. Could you show the code that is using your ico file?
Whatever icon file you are using for the menu will be used for it.
So just change the icon file your project is using. Visual Studio has an icon editor.
Cheers,
Adam Nagy
Autodesk Platform Services
