put back static value status iin revision table
stefaanboel
Message 1 of 1
stefaanboel
we worked out this piece of code to reset all cells from the approved folder in the revision table.
but it's not working, is it because this function does not exist for the revision table? It does work for the partslist :s
Public Sub RevisionTableMult()
Dim invDDoc As DrawingDocument
Dim invPL As RevisionTable
Dim invPLCell As RevisionTableCell
Dim intRow As Integer
Dim invPLRow As RevisionTableRow
    Set invDDoc = ThisApplication.ActiveDocument
    Set invPL = invDDoc.ActiveSheet.RevisionTables.Item(1)
     For intRow = 1 To invPL.RevisionTableRows.Count
        Set invPLRow = invPL.RevisionTableRows.Item(intRow)
       Set invPLCell = invPLRow.Item("APPROVED")
'resets the cell back to the parametric value...
         invPLCell.Static = Active
    Next intRow
End Sub
If this is the solution, push the solution button Smiley Wink (and maybe some kudos)
Replies (0)
