Pushing Assembly/Part parameters to connected drawing
Hey guys,
i have a question: is it possible to push parameters from an assembly/part to a connected and similiarly name drawing?
I'm attaching my code (it's a BFD to me...don't hurt me too bad)
Dim partDoc As PartDocument
'partDoc = ThisApplication.ActiveDocument
Dim RawPartNumber As String
Dim DrawingOfModel As String
Dim FinPartNumber As String
'Dim propertyName As String = "MOTOR_HP"
RawPartNumber = ThisDoc.PathAndFileName(True) 'without extension
MessageBox.Show(RawPartNumber, "Title")
FinPartNumber = Replace(RawPartNumber,"-0__ATL_000.iam","")
MessageBox.Show(FinPartNumber, "Title")
DrawingOfModel = Replace(RawPartNumber,"-0__ATL_000.iam","-1__ATL_000.idw")
MessageBox.Show(DrawingOfModel, "Title")
iProperties.Value("Custom", "MOTOR_HP") = Parameter(DrawingOfModel,"MOTOR_HP")
for some reason, i get an error saying it couldn't find the file, but when i run
ThisDoc.Launch(DrawingOfModel)
it opens the file so i know it can find it.
I would take a slightly different approach.
I would always pull data to the drawing, from the drawing itself, in the image below, you can see that it's really easy to get to the user parameters of a part.
BUT, depending on the application, you probably don't need any iLogic, if you are just looking to pull data from the part/assembly.
If you add text to your drawing, you can include any of the model or user parameters on the drawing.
