Purging / Deleting instances of Sketched Symbols
GeorgK
Advisor Advisor
GeorgK
Hello together,
I found this piece of code to delete instances of sketched symbols.
https://forums.autodesk.com/t5/inventor-customization/vba-purging-deleting-isntances-of-sketched-sym...
Public Sub Sketchsymbol_Delete()
Dim oDoc As DrawingDocument
Set oDoc = ThisApplication.ActiveDocument
Dim oSheet As Sheet
For Each oSheet In oDoc.Sheets
    oSheet.Activate
    Dim oSketchedSymbolDef As SketchedSymbolDefinition
    Set oSketchedSymbolDef = oDoc.SketchedSymbolDefinitions.Item("REVISION BLOCK")
    Set oSheet = oDoc.ActiveSheet
    Dim oTG As TransientGeometry
    Set oTG = ThisApplication.TransientGeometry
    Dim oSketchedSymbol As SketchedSymbol
        For X = 1 To oSheet.SketchedSymbols.Count
            If oSheet.SketchedSymbols.Item(X).Name = "REVISION BLOCK" Then
            oSheet.SketchedSymbols.Item(X).Delete 'Delete it from each sheet
        Next
Next
oSketchedSymbolDef.Delete 'Delete it from the library
End Sub
When I run the code not all sketched symbols are deleted. I have to run the code several times. Is there any solution to run the code only once to delete the sketched symbols?
Georg
Hi Georg,
In your piece of code it will delete the sketched symbol if its name is set to REVISION BLOCK else it will not delete. my modified code might be helpful for you.
Dim oSheet As Sheet
    For each oSketchedSymbolDef in oDoc.SketchedSymbolDefinitions
        oSketchedSymbolDef.delete 'It will delete all the sketched symbols
   next
Next
End Sub
GeorgK
Hello Srinivas,
I would like to delete only the "REVISION BLOCK". But in my case I have several "REVISION BLOCK" in my drawing. The problem is that I have to use the program several times to delete all the "REVISION BLOCK".
Do you have the same error?
Georg
Try this code
Dim oSheet As Sheet
    For each oSketchedSymbolDef in oSheet.SketchedSymbols
if osketchedSymbolDef.Name = "REVISION BLOCK" then oSketchedSymbolDef.delete 'It will delete all the sketched symbols
endif next Next End Sub
GeorgK
Hello Srinivas,
thank you very much. It's working now.
Georg
