VBA - Purging/Deleting isntances of Sketched Symbols
thomas.anderson188
thomas.anderson188
Good morning all!  I have been writing a few programs to help me speed up some of the nittygritty work that we all have to do from time to time.  Currently there is a need to go through a very large quantity of drawings that have revision blocks and revision tags in them.  For ease, they are just blocks that are inserted as Sketched Symbols.  These symbols are built into our standard template file, so they will always be available for use, but I want to purge them off of the actual document so they aren't used anywhere.  Currently I have the following code but I get a "Method 'Delete' of object 'SketchedSymbolDefinition' failed"
I've bounced around the code quite a bit, and I don't know the solution.
Thanks for all the help!
Public Revision As Integer
Private Sub Validateform3()
    If Revision_Check = 0 Then
        Revision = 0
    Else
        Revision = 1
End Sub
Private Sub CommandButton1_Click()
    Unload Me
End Sub
Private Sub Revision_Check_Click()
    Call Validateform3
End Sub
Private Sub Run_Cleanup_Click()
   Call Validateform3
    Dim oDoc As DrawingDocument
    Set oDoc = ThisApplication.ActiveDocument
Dim oSketchedSymbolDef As SketchedSymbolDefinition
    If Revision = 1 Then
        For Each oSketchedSymbolDef In oDoc.SketchedSymbolDefinitions
                If oSketchedSymbolDef.Name = "REVISION BLOCK" Then
                oSketchedSymbolDef.Delete
                Else
        Next
End Sub
Thomas,
I found that first if must be deleted from the sheet before it could be removed from the library. See code below.
 Public Sub Sketchsymbol_Delete()
Dim oSheet As Sheet
For Each oSheet In oDoc.Sheets
    oSheet.Activate
    Set oSketchedSymbolDef = oDoc.SketchedSymbolDefinitions.Item("REVISION BLOCK")
    Set oSheet = oDoc.ActiveSheet
    Dim oTG As TransientGeometry
    Set oTG = ThisApplication.TransientGeometry
    Dim oSketchedSymbol As SketchedSymbol
        For X = 1 To oSheet.SketchedSymbols.Count
            If oSheet.SketchedSymbols.Item(X).Name = "REVISION BLOCK" Then
            oSheet.SketchedSymbols.Item(X).Delete 'Delete it from each sheet
        Next
Next
oSketchedSymbolDef.Delete 'Delete it from the library
End Sub
Let me know if this works for you.
Please Kudo if this solution works for you.
Wayne
thomas.anderson188
Thank you very much! That was exactly the problem and she is up and running now!
