Punching tools positioning with offset
Marco_PeronXTBPH
Message 1 of 1
Marco_PeronXTBPH
Hi everyone,
in this function I am currently looking for a sketch with a given name where inside there is a single constrained point and with dimensions defined in the parameters, to then insert a punch tool feature.
Sub Main
	Dim sketchName As String = RuleArguments("sketchName")
	Dim iFeatureName As String = RuleArguments("iFeatureName")
	Dim offset As Integer = RuleArguments("offset")
	Dim gradi As Integer = RuleArguments("gradi")
	DeleteFeature(sketchName)
	If iFeatureName = "0" or iFeatureName = "" Then Exit Sub
	InsertPunch(sketchName, iFeatureName, offset, gradi)
End Sub
Sub DeleteFeature(Optional stringaRicerca As String = "")
	Dim oFeatures As PartFeatures
	Dim esegui As Integer
	oFeatures = ThisApplication.ActiveDocument.ComponentDefinition.Features
	If stringaRicerca = "" Then
		esegui = MessageBox.Show("Eliminare tutte le lavorazioni presenti nella parte?", "ATTENZIONE", MessageBoxButtons.YesNo, MessageBoxIcon.Exclamation)
	If esegui = 6 Or stringaRicerca <> "" Then
		For Each oFeature As PartFeature In oFeatures
			If Left(oFeature.Name, Len(stringaRicerca)) = stringaRicerca Then
				oFeature.Delete(True)
		Next
End Sub
Sub InsertPunch(sketchName As String, iFeatureName As String, _
			  Optional offset As Integer = 0, Optional gradi As Integer = 270)
	Dim iFeaturePath As String = "...\_iFeature\PunchTools\"
	iFeatureName = iFeaturePath & iFeatureName & ".ide"
	Try
		Dim oPartDoc As PartDocument = ThisApplication.ActiveDocument
		Dim oSMDef As SheetMetalComponentDefinition = oPartDoc.ComponentDefinition
		Dim oSMFeats As SheetMetalFeatures = oSMDef.Features
		oPTFeats = oSMFeats.PunchToolFeatures
		Dim oPunchTool As iFeatureDefinition = oPTFeats.CreateiFeatureDefinition(iFeatureName)
		Dim oCPoints As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection
		oSPts = oSMDef.Sketches.Item(sketchName).SketchPoints
		For Each oSP As SketchPoint In oSPts
			If oSP.HoleCenter Then
				oCPoints.Add(oSP)
		Next
		Dim rad As Double = gradi * Math.PI / 180
		oPTF = oPTFeats.Add(oCPoints, oPunchTool, rad)
		oPTF.Name = sketchName & "_" & oPTF.Name
	Catch ex As Exception
		Logger.Error("Lavorazione non creata. - MOTIVO: " & ex.Message & " - STACK: " & ex.StackTrace)
	End Try
End Sub
now I would need to be able to insert that punching with a certain offset compared to the point present in the sketch, avoiding the creation of new points in the sketch so as not to insert more punches every time the rule runs with an offset different from the previous one.
Replies (0)
