Issue in replacing process
rbertoletti
Message 1 of 1
rbertoletti
Hi guys,
I'm working on a "convert" rule which replace all the components (including all sub assemblies) in order to create a indipendent copy of a "Template assembly".
Unfortunately some components (often Sheet metal components) are not changed by the process and some perform the replace command wrongly.
This is the rule:
Sub Main()
Dim oAsmDoc As AssemblyDocument
oAsmDoc = ThisApplication.ActiveDocument
Call Iterate(oAsmDoc.ComponentDefinition.Occurrences, 1)
iLogicVb.UpdateWhenDone = True
RuleParametersOutput()
InventorVb.DocumentUpdate()
InventorVb.DocumentUpdate(False)
End Sub
Private Sub Iterate(Occurrences As ComponentOccurrences, Level As Integer)
Dim oPanelCode As String = ThisDoc.FileName(False)
Dim oComp As ComponentOccurrence
Dim oComps As ComponentOccurrences
For Each oComp In Occurrences
On Error Resume Next
If oComp.DefinitionDocumentType = kAssemblyDocumentObject Then
Call Iterate(oComp.SubOccurrences, Level + 1)
'[REPLACE
Dim oOccName As String = oComp.Name
Dim oOccDoc As Document = oComp.Definition.Document
Dim oOccFullFileName As String = oOccDoc.FullFileName
'DEFINES BACKSLASH AS THE SUBDIRECTORY SEPARATOR
Dim strCharSep As String = System.IO.Path.DirectorySeparatorChar
'FIND THE POSITION OF THE LAST BACKSLASH IN THE PATH
oBackSlsPos = InStrRev(oOccFullFileName, "\", -1)
'GET THE FILE NAME WITH THE EXTENSIONS
oOccFileName = Right(oOccFullFileName, Len(oOccFullFileName) -oBackSlsPos)
'REPLACE THE TEMPLATE FILE WITH THE PANEL FILE
Dim oPanelItemsDirectory As String = ThisDoc.Path & "\" & "\LIBRARY\"
Dim oNewComp As String = oPanelItemsDirectory & oPanelCode & "_" & oOccFileName
Component.Replace(oOccName, oNewComp, True)
Else
'[REPLACE
Next
End Sub
The items not changed are all the "LP" items:
but as you can see all the other items are replaced correctly.
Also in the LINER_1 assembly the LP item replace the original "P_LPCT_CA-47V_1.ipt" with the n.er 35:
Please, let me know how to fix it.
Thanks in advance
Replies (0)
