Punches tables for part drawing
Ahmed.shawkyXTZHN
Ahmed.shawkyXTZHN
Hi all , I have the below code which is working fine for assembly , how can I modify it to be applicable to parts level so table will be in part drawing instead of assembly , also is it possible to link it so it will come to sheet metal part table with length width thickness , thanks.
Dim oDrawing As DrawingDocument = ThisDrawing.Document
Dim oSheet As Sheet = oDrawing.ActiveSheet
Dim oHoles As New List(Of KeyValuePair(Of String, Integer))
Dim oPunches As New List(Of KeyValuePair(Of String, Integer))
Dim oAsm As AssemblyDocument = oSheet.DrawingViews(1).ReferencedDocumentDescriptor.ReferencedDocument
Dim oCustomProps As PropertySet = oAsm.PropertySets("{D5CDD505-2E9C-101B-9397-08002B2CF9AE}")
For Each oProp As Inventor.Property In oCustomProps
	If oProp.Name.StartsWith("Hole: ") Then
		oHoles.Add(New KeyValuePair(Of String, Integer)(oProp.Name.Replace("Hole: ", ""), oProp.Value))
	ElseIf oProp.Name.StartsWith("Punch: ") Then
		oPunches.Add(New KeyValuePair(Of String, Integer)(oProp.Name.Replace("Punch: ", ""), oProp.Value))
Next
Dim oHoleTable As CustomTable
Dim oPunchTable As CustomTable
Dim oTG As TransientGeometry = ThisApplication.TransientGeometry
If oHoles.Count > 0
	Dim colTitles(1) As String
	colTitles(0) = "Diameter"
	colTitles(1) = "Number"
	oHoleTable = oSheet.CustomTables.Add("Holes", oTG.CreatePoint2d(10, 10), 2, oHoles.Count, colTitles)
	oHoleTable.Columns.Item(1).ValueHorizontalJustification = HorizontalTextAlignmentEnum.kAlignTextCenter
	For i = 1 To oHoles.Count
		oHoleTable.Rows(i).Item("Diameter").Value = oHoles(i - 1).Key
		oHoleTable.Rows(i).Item("Number").Value = oHoles(i - 1).Value
	Next
If oPunches.Count > 0
	colTitles(0) = "Name"
	oPunchTable = oSheet.CustomTables.Add("Punches", oTG.CreatePoint2d(If (oHoleTable Is Nothing, 10, 10 + oHoleTable.RangeBox.MaxPoint.X - oHoleTable.RangeBox.MinPoint.X) _
	, 10), 2, oPunches.Count, colTitles)
	oPunchTable.Columns.Item(1).ValueHorizontalJustification = HorizontalTextAlignmentEnum.kAlignTextCenter
	For i = 1 To oPunches.Count
		oPunchTable.Rows(i).Item("Name").Value = oPunches(i - 1).Key
		oPunchTable.Rows(i).Item("Number").Value = oPunches(i - 1).Value
	Next
JelteDeJong
try this:
Dim refDoc As Document = oSheet.DrawingViews(1).ReferencedDocumentDescriptor.ReferencedDocument
Dim oCustomProps As PropertySet = refDoc.PropertySets("{D5CDD505-2E9C-101B-9397-08002B2CF9AE}")
Next
Dim insertX = 10
If oHoles.Count > 0 Then
	oHoleTable = oSheet.CustomTables.Add("Holes", oTG.CreatePoint2d(insertX, 10), 2, oHoles.Count, colTitles)
	Next
	insertX = oHoleTable.RangeBox.MaxPoint.X
If oPunches.Count > 0 Then
	oPunchTable = oSheet.CustomTables.Add("Punches", oTG.CreatePoint2d(insertX, 10), 2, oPunches.Count, colTitles)
	Next
	insertX = oPunchTable.RangeBox.MaxPoint.X
If (refDoc.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}") Then
	Dim partDoc As PartDocument = refDoc
	Dim sheetMetalDef As SheetMetalComponentDefinition = partDoc.ComponentDefinition
	If (sheetMetalDef.HasFlatPattern) Then
		colTitles(0) = "Dimension"
		colTitles(1) = "Value"
		oHoleTable = oSheet.CustomTables.Add("Sheet size", oTG.CreatePoint2d(insertX, 10), 2, 2, colTitles)
		oHoleTable.Rows(1).Item("Dimension").Value = "Width"
		oHoleTable.Rows(1).Item("Value").Value = Math.Round(sheetMetalDef.FlatPattern.Width, 3)
		oHoleTable.Rows(2).Item("Dimension").Value = "Length"
		oHoleTable.Rows(2).Item("Value").Value = Math.Round(sheetMetalDef.FlatPattern.Length, 3)
Jelte de Jong
Blog: hjalte.nl - github.com
