Pulling data for parameters from spreadsheet
BeasterlyJEC92
BeasterlyJEC92
I am trying to grab parameters from a spreadsheet to generate parts (similar to an i-part but without the link to the base part).
I have got it to grab the parameters I add to the sheet, but it is also assigning values to parameters that are not in the spreadsheet? seems to default to the first cell. How do I stop this behavior?
Incorrect values:
Is there a way to tell it to only grab parameters that exist in the spreadsheet that match the model parameters?
Current code:
'sets multivalue list of all model parameters
ModParams = ThisDoc.Document.ComponentDefinition.Parameters.ModelParameters
'sets associated Excell file, Passes user text for file name:
ExcelFile = "C:\CHS\Small Cell\" & Exc_file & ".xls"
'Passes user text for coloumn name containing values:
Col = Col_Name
'Passes user text for sheet name:
ExSheet = Excell_Sheet
'opens the excell file
GoExcel.Open(Exc_file, ExSheet)
'sets where to find the title row
GoExcel.TitleRow = 1
'cycle through all numerical model parameters And Do a thing.
For Each oParam In ModParams
	If oParam.Units <> "Text" And oParam.Units <> "Boolean" Then
		ParameterName = oParam.Name
			'find in spreadsheet Row matching the inventor parameter name
			Ex_Parameter_Name = GoExcel.FindRow(ExcelFile, ExSheet, "Parameter", "=", ParameterName)
			'get the value from user specified coloumn
			value = GoExcel.CurrentRowValue(Col)
			Parameter(ParameterName) = value
Next
GoExcel.Close
InventorVb.DocumentUpdate()
Example of parameters I want to grab:
A.Acheson
hi @BeasterlyJEC92
Have you assigned a column name of a object type string to the variable col? At the moment you have a variable set to another vairable
Col = Col_Name
If you don’t find the parameter name in the excel sheet the code should  return -1 and you can use this in an if statement along with a continue for line to move to next parameter.
Regards
Alan
op_thorsager
the long way to do this would be to use goExcel.Cellvalue instead.
example could be
Parameter(parameter) = GoExcel.CellValue
then do that for all your parameters. its bothersome to do it this way, but it will help you specify exactly what you want to change.
note: are you sure that your sketches are fully constrained? the "d" parameters aren't a parameter you've named, so it could be that inventor adjusts those values because of how you change values of dimensions you've named.
BeasterlyJEC92
Your a absolute genius, thank you!
