iLogic to Set Pre-Defined Set Flat Pattern Orientation
KsweenyQ4WCU
KsweenyQ4WCU
In "Edit Flat Pattern Definition", I can create a list of orientations to select between, but it is a manual process. Is there a way to do this with iLogic? It seems like all the orientation-related functions are to get read-only properties, but I need to be able to write which I want. Any help would be greatly appreciated.
JelteDeJong
You can activate the orientation like this.
Dim doc As PartDocument = ThisDoc.Document
Dim def As SheetMetalComponentDefinition = doc.ComponentDefinition
For Each orientation As FlatPatternOrientation In def.FlatPattern.FlatPatternOrientations
    If (orientation.Name = "A-C") Then
        orientation.Activate()
Next
Jelte de Jong
Blog: hjalte.nl - github.com
KsweenyQ4WCU
Hi, this does exactly what I want it to do, thank you
