PROTECT i-LOGIC RULES AND GRANTING ACCESS TO FORM DIALOG BOX
I have one assembly with ilogic rules and created respective FORM with desired parameteres.
Now, I want to send this assembly to one of our vendor, where he must not have access to i-Logic rules.
Vendor must have access to FORM only, so that he can change the values of parameters and generate desired configuration.
Please help me how to do the same.
MegaJerk
There is no practical way of doing what you’re trying to accomplish. If you’re giving somebody a file, there is little you can do to prevent him or her from snooping around and possibly changing something. While it may be possible to write a longwinded plugin to prevent people from accessing iLogic rules / forms on your local machines, it does nothing to thwart people in the outside world (who cannot be forced to install a plugin!).
If my solution worked or helped you out, please don't forget to hit the kudos button 🙂
iLogicCode Injector: goo.gl/uTT1IB
GitHub
RodrigoEiras
Hi Mahesh,
It sounds to me like what you are trying to do is what Configurator 360 does, but I have no experience about how it works.
Best regards
Thanks for your information.
