Inventor VBA Macro - Left justify the title text on a custom table?
I'm having trouble getting the Title text to justify to the left on a General table in Inventor. Is it possible? If so,
can someone please provide some example VBA code that will force the title text to justify to the left?
Everything I have tried so far does not work. I'm starting to wonder if it is hard coded into Inventor to keep the title text centered.
Thank you in adavnce for taking a look.
xiaodong_liang
Autodesk Support
Autodesk Support
Sorry there is not such API. in UI we can’t justify it neither, it should be controlled by table style(Table(ANSI))-> text style(Note Text (ANSI)). But if you modify the justifications they don’t apply to the custom table title. Sorry if this is a bad news to you.
