PropertySets() with empty string crash
This vba code crash Inventor (after clicking on debug):
dim mat as string
mat = ""
Call ThisApplication.ActiveDocument.PropertySets(4).Add(mat, "MAT")
Work around:
if mat = "" then
Call ThisApplication.ActiveDocument.PropertySets(4).Add("", "MAT")
else
end if
Same problem for:
dim mat as string
mat = ""
ThisApplication.ActiveDocument.PropertySets(4).Item("MAT").Value = mat
ThisApplication.ActiveDocument.PropertySets(4).Item("MAT").Value = ""
Works without problem
Jan,
I haven't been able to reproduce the problem. Could you give more specific
steps that lead to the crash? Also, is this specific to some files or does
it happen always (new documents as well)?
Sanjay-
wrote in message news:4926977@discussion.autodesk.com...
dim mat as string
mat = ""
Work around:
if mat = "" then
else
end if
Same problem for:
dim mat as string
mat = ""
See error report send on 15 aug 2005 8:54
Hotfix TS1052452 does fix it.
