IV10SP1: Possible to find small edges?
Dear all,
Not that up on the VB side of IV. Had a quick look through the programming help and couldn't figure out if this is viable:
Is it possible to highlight all edges on a part less than a (user) set length?
Would be useful for checking inadvertent break throughs of holes through surfaces, etc.
Kind regards,
Simon Heywood
Tronic Ltd UK
Simon,
I've attached a macro that highlights all edges less than a user specified
length (specified in cms). It should work for all edge types (linear,
circular, etc.)
Sanjay-
Public Sub HighlightEdges()
Dim MinLength As Double
MinLength = InputBox("Enter minimum length in cm")
Dim oDoc As PartDocument
Set oDoc = ThisApplication.ActiveDocument
Dim odef As PartComponentDefinition
Set odef = oDoc.ComponentDefinition
Dim oHS As HighlightSet
Set oHS = oDoc.HighlightSets.Add
Call oHS.SetColor(255, 0, 0)
Dim oEdge As Edge
For Each oEdge In odef.SurfaceBodies(1).Edges
Dim MinParam As Double
Dim MaxParam As Double
Call oEdge.Evaluator.GetParamExtents(MinParam, MaxParam)
Dim EdgeLength As Double
Call oEdge.Evaluator.GetLengthAtParam(MinParam, MaxParam,
EdgeLength)
If EdgeLength < MinLength Then
oHS.AddItem oEdge
Next
If oHS.Count > 0 Then
MsgBox "Edges less than " & MinLength & " cms in length highlighted
in red."
oHS.Clear
End Sub
wrote in message news:4927005@discussion.autodesk.com...
Dear all,
length?
surfaces, etc.
Kind regards,
Simon Heywood
Tronic Ltd UK
Sanjay,
Thanks very much. I hadn't expected so much of an answer! I was only looking for whether it was possible or not, and then expected to spend a few weeks figuring it out. You've saved me a great deal of time.
I had to add in an "On Error Resume Next" before the For Loop though as I kept getting a "Run-time error '91': Object Variable or With block variable not set" on the line:
I think this error is a bit miselading as the loop had obviously run a few times since edges were highlighted in the model.
Many thanks again.
Simon Heywood
Tronic UK Ltd
I was looking for something like this, However I was wondering if you knew if there was a way to keep the edges highlighted after the textbox is closed, or some way to be able to do edits on the solid while the edges are highlighted?
